what happens in this situation is not dissimilar to normal detonation, the fuel sits in the cylinder because it has not combusted, the engine comes back down off the limiter and ignition is given back to the spark plugs, the compression stroke comes up the spark plug ignites, fuel and air burn, but now you have excess fuel sitting ontop of your piston and once that is ignited you have your self a instant hot spot,
on the next compression stroke if that hot spot is still there your combusting fuel while the piston is still travelling upward in its stroke.
There are two ways to go about this.
set the Bee*R limiter to the same limit your ecu has so both spark and fuel are cut at the same time,
or let the factory limiter do it's thing, its there for a reason, the manufacturer put it there for a reason .
but it comes down to your right foot, the driver, not the machine or the electronics running it, you want to push your car then by all means do so, but make sure you have money stashed away for when you bend a conrod. cause they arent cheap.
The limiter itself is probably ok if used as intended.
Its the silly people that go around altering it to 4000rpm etc, and then deliberately having it slap flames out and so on because they sit with the throttle open/limiter for a few seconds then back off to get the flames and continue to do so for 30-40 seconds each time.
Who would deliberately hold thier car on the limiter? Only a fool, and those are the people that are destroying motors turbos and otherwise :cheers:
To the person asking "IF" a turbo was upto the task?
Never. No turbo will handle the shaft impacts that explosions in the housing/exhaust will cause over time... i would be surprised if it did.
If you use the limiter, as a limit and not as a flame thrower, it'll be fine however.
My 2c, flames are sick we all love em but at the end of the day if your car soes not blow flames from stock making it do so will probably shorten the engines life. i had a straight through exhaust fitted last week and after a good amount of revs at full throttle on decel if just nudge the accelarator as light as ya can it gives a nice bang and a big flame so, maybe try that :P
nice one so blocking it makes more flames? maybe if somone is after flames they can try this and not cause as much damage???? mine is all stock all i have done is bigger turbo,walbro pump, pod and exhaust, the RB family of engines would just about do it from stock wouldnt they? my N/A VL did!
i dont see how it would put more stress on the motor itself. For example, fuel sprays, theres no spark, the piston still goes down on its "power" stroke and when it goes back up it would blow most of the fuel out the exhaust valve on the exhaust stroke. Abliet there maybe some fuel vapour left over, but its just going to get more fuel on the next stroke anyway. There wont be an unexpected explosion inside the cylinder, its just that when the system ignites its next power stroke it ignites the rest of the fuel in the exhaust.
Could be wrong, but thats the way i picture it
So if theres no spark, whats creating the "power" stroke other than the iniertia of the previous stroke with the spark? Im guessing that the inconsistant balance in the power/cut/power stroking (lol) is what causes conrods etc to bend..
Just throwing an idea out there.
Im pretty sure you should google Bee R rev limiter and Engine Failure, the thing would be great if used correctly but most people dont.
I have seen an actual flame thrower which you can buy, why dont u try that?
Did the hard work for you http://www.hotlicksexhaust.com
Edited by DECIM8
hmmm in regards to flames.. i got a 'special' cat and mine still doesnt have any flames :down: makes louder pop noises now though when you tap accelerator. could it be because of the catbak i have ? specificaly the muffer thingy in in the middle ???
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
