Allright i have a basically stock standard r33 s2 skyline and want to make the above power figures..... i would like it to be a good allrounder but a good 1/4 mile car is what im mostly interested in....
Will a highflowed turbo do the trick and am i forgetting anything from the below list or is anything not needed..
-fmic
-full turbo back exhaust 3 1/2 or larger
-upgraded turbo hopefully highflowed
-forward facing plenum
-fuel pump, regulator and injectors
-coilovers
-e-manage ultimate/power fc
-high mount manifold
-internals but im unsure of what...
-new clutch
-new diff?
any suggestions would be gr8
cheers nick
https://www.sau.com.au/forums/topic/215996-350-400-kw-skyline/
Probably been covered a half-dozen times, but a mate just did 509hp (377kw) with the following setup (RB25):
Internals:
Arias Pistons (although I'd suggest Tomei)
Pauter Conrods
TOMEI Gasket Kit
Nissan N1 Bearings
ARP Rod bolts
JUN Valve guides
ARP Head Studs
HKS cams (264)
HKS valve springs
HKS Cam gears
JUN High Flow Oil Pump
Hardware:
Garrett GT35R
Steampipe Manifold
HKS 50?mm External Gate
GReddy Plenum
880cc Sard Injectors
Bosch 044 Fuel Pump
Apexi PowerFC
FMIC
Exhaust
Blitz SBC Spec-R Boost Controller
Driveline:
OS Giken Twin Plate Clutch
OS Giken 5-speed Gearset
Cusco 2-way mech
Don't expect any change from 25k.
Internals:
Pauter Conrods
TOMEI Gasket Kit
Nissan N1 Bearings
ARP Rod bolts
JUN Valve guides
ARP Head Studs
HKS cams (264)
HKS valve springs
HKS Cam gears
Hardware:
Garrett GT35R
Steampipe Manifold
GReddy Plenum
Bosch 044 Fuel Pump
Apexi PowerFC
FMIC
Exhaust
Driveline:
Cusco 2-way mech
Why the hell did your mate by Arias pistons? When it looks like he has spent serious coin on everything else.
oh ok didnt relaise...
say about 300kw
Read the dyon sticky.
You'll see no-one with a hi-flow is making much more than 250rwkw as its simply impossible to get much more than that with that size of turbo.
I think you need to do some more reading mate, there are some great basic threads to gets started.
20k is a BARE minimum for 350-400kw
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
