Guest gts32t
I have 2 X GTR rims for sale, original 16 X 8s in charcoal, $400 onco
Panasonic VX303 double Din Head Unit, Like new $500 with Manual
4 X R32 GTS-t rims for sale, original 16 X 6 1/2 alloys, $400 with tyres
R32 GTS-t Bonnet, Dark blue with purple pearl, original paint, no dent, no rust, $300 onco
Reason for selling just purchased a carbon fibre bonnet for the car, a new set of rims and a new sound system - the double din was not practical for my application as it was 2 large, now replaced with a cheap ass single din and a 3 gauge cluster - you dont need a big stereo to drift
https://www.sau.com.au/forums/topic/216-2-x-r32-gtr-rims/
Guest gts32t
any pics of the rims?
any tyres on it?...if so how much rubber has it got left[/quote:0c49748798]
The GTS-t rims have about 70-80% rubber on them, so they are still good for about 8months worth of road travel unless your driving habits are very aggressive, will get some pics for you today
https://www.sau.com.au/forums/topic/216-2-x-r32-gtr-rims/#findComment-9017
  • 4 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
