Well, my hks BOV is basically staying open, which means my car is a shit to drive... just one massive boost leak.
As you can see from pic, its not on factory position, but in front intake piping (from IC to cross over pipe).
I have ordered a new BOV, but wont be here for a few weeks... does anyone have a stock bit of piping I can borrow?? or even an old bov that will fit into the current pos.
thanks
dave!!
https://www.sau.com.au/forums/topic/21601-need-your-help-with-intake-pipe/
um, no idea why it stays open, but its not shutting now.. i attacked with a hammer and screw driver :D
DJ - i did that with some really thick plastic I got... only thing is its too damn hard to cut a perfect circle with something so thick, so its still leaking a lil bit.
Originally posted by DJ_L3ThAL
lol go to bunnings bro
lol i remmber when i wanted bunnings sheet metal to my pod shield
but it only came in a large 10 dollar sheet.
too pov to pay that much, so i asked the guy... is there anyway i can buy half of this?
so he punched it in the middle a bit and goes... its damaged now... 5 bucks only.
:D
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
