eng cert does not come from workshops, you have to go to the pit and get a list of approved engineers. The ones I had, he is a retired mechanical engineer.
he looked at the Australian standards for the vehicle and compare it with what you have. he'll then make a report to be submitted to the pits.
They have nothing to do with garages as they are meant to me impartial third party
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3816310
pit, vehicle inspection centre I think its named that way because of the hole underneath to inspect the underside of the car. They do it this way in W.A not sure in melb. I don't recomend getting eng cert unless you got yellow sticker.. its quite expensive
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3816448
Im using the guys in Braeside - Enkelman and Associates
They are quite good, a few people i know have used them now and their prices are some of the best in Vic.
Some engineers are charging far too much but these guys are good priced
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3817782
Really im just about to go get my R32 GTST complainced can they beat 1200??? i got most of the work such as oil change, brakes , everything that makes car RW, its fully stock except exhaust it has a cat thow, and pod filter but its properly put on and jdoes not jiggle around or anything , plus my car was bought in under 15 yo rule one of the last to be brought in under that,
Edited by BRUNSKIGTST
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3818896
I also used Enkelman and Associates for my Pulsar, I needed an engineers to legally drive around with an SR20DET in the car. It was expensive, but they were extremely reasonable about the modifications.
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3819140
Compliance and Engineers are two totally different things.
You need an engineers as but a part of compliance
$1200 is normal for compliance non DIY (things like AC gas, seat belt are other things that need doing etc)
https://www.sau.com.au/forums/topic/216013-engineers-cert/#findComment-3819206
