Hey guys,
Pulled my standard turbo's off my R34 GTR and i'm amazed at how many more hoses, lines and pipes there are on the factory setup. It got me thinking, when i've looked at a lot of 26's that have been modded with low mount twins etc, a lot of the clutter and work that is there from factory is gone, it seems all the lines and piping is much tidier and there would appear to be a lot less of it! Is this the case? i'm wanting to follow similar procedure if thats the case, before i put my other turbo's on id like to purchase whatever aftermarket parts are needed to tidy it all up and simplify the setup. If im completely off track let me know! Otherwise any information on what gets done would be awesome! Thanks.
Edit - I am planning the purchase of a HKS Hard Pipe kit, thats about the only one i've planned thus far though.
Edited by Got Boost?
Are you sure dude?
Which setups are you talking about?
There is a need for just about everything if your going the stock position low mounts.
Maybe it "looks" tidier because of people painting/polishing of the piping perhaps?
Careful altering the piping though, sometimes it can cause mild shuffling due to the new pipe meet points etc
Are you sure dude?
Well its more then possible that when it gets redone, the lines and piping are just organised a lot better, tidier and hidden etc. I didn't get to examine the setups, just look across from the top and admire how neat it was.
If i remember over the weekend ill grab a shot of mine from the side, uses all the factory gear except the boost solenoid really... and just with a bit of paint it looks totally different
on the intake side there is the PCV valve, AAC valve, air chamber, bov lines, boost lines about 20 hoses. but unless you are getting rid of the valves (which help idle, cold start, aircon etc) there's not much you can do.
on the turbo side also not much you can do. you need boost line to the wastegates, and the turbos are air and water cooled.
I reckon there is a madman working in nissan's design department somewhere though. "muahahha lets add a loop to this line! what if we ran bost lines right around the engine? lets loop it all with coolant too muahahhaha"
second on the mad engine design crew!
Just got rid of just about all of them the 2 main vacum pipe outlet now go to the brake and clutch boosters 1 water line round rear of engine to turbos and another between the thermostat housing and rear of block. 1 small vacum line for boost control an one to bov rest plugged up
lol definately was a madman working in the design department
Agreed; its like a birds nest of lines on the turbo side of the 26. This is what made the decision to go a single highmount turbo much easier for me.
Unfortunately, all the lines are neccessary if you want to maintain twin low mounts in the standard position, and its a street driven car.
I painted the hard water lines in a black exhaust paint, which made them disappear a bit, but it also makes them hard to maintain. My engine was also on a stand, so it was much easier to do.
Shaun.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
