Hi all looking at purchasing this HDI FMIC kit. Do you think it will fit my 1997 series 1 rs4 stagea? It is stock.
dimensions are 300x600x78
apparently its for a 33 gtst and a 34 gtt
acording to the seller its bearly been used, and i will save a little bit of coin getting it 2nd hand, plus i get to help out a fellow SAU member.
cheers chris
https://www.sau.com.au/forums/topic/216164-will-this-fmic-fit/
Yes it will fit
Hi Darrin, I am also interested in something like this for my vehicle. Is there much involved in prep work with existing piping to make one slip into a 260RS? Is it essential that the inlet outlet pipes on pre-cooler face rearward (biased towards engine bay)?
Regards GW
Regards GW
This type and size of intercooler would be either a sidewards or backwards step compared to what is already in your 260RS now.
If need to upgrade what you have now, the best cooler is a 100mm GTr replacement like the attached link
No mods required to piping and should be a direct fit with regards to clearances etc
Your factory r33 GTR cooler in the 260rs is good for upto 500hp, so unless you are producing those numbers or do alot of track work stick to what you have.
http://justjap.com/store/product.php?produ...=298&page=1
Thanks Darrin, (pockets dosh for other goodies).
Cheers GW
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
