Just bought a walbro pump from them. Good support and communication before and after I made the purchase... Arrived within a week, was wrapped up well in bubblewrap...
They are pleasant to deal with and I wouldnt hesitate to use them again...
P.S. dont know if the site works, but their SAU ones do...
Bought a turbo and a set of splitfires off Aaron (Slide)
top bloke(s) to deal with thats for sure, IMHO
turbo took a while (was snowed under with orders) but I wasnt worried, the splitfires were delivered in 2 days
I bought stuff from them on probably 20 occasions, they are always cheap and reliable.
But I haven't been able to get to their website in the last couple of weeks either. If its down for a rebuild they should have a message that says so. Just pm "slide" through here instead in the meantime
Would anyone happen to have a Contact Number other than Aaron's number? he's never picked any calls I've made to him.
I just had to get a Dodgey Clutch plate out and new Clutch kit installed - I was wishing to speak to someone from the business.
I've looked around quite a bit and it seems they don't have a contact other than Aaron's mobile.
cheers
Hi Guys
The website has suffered some big delays whilst upgrading.
Porting all the products to the new setup aswell as a pretty big customer base has proven to be impossible.
We are fishing around for a developer to clean up the mess and get the site back up and running now.
All orders and quotes are still being made through SAU and a number of other forums and will always continue to do so.
A simple oscommerce website was just too small for the inventory we need to list and need something much more practical.
cheers
Send us an email or pm asap and we will contact you straight away.
[email protected]
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
