hey guys, i sused my car lastnight and saw that my passenger side fog light id guess ud call it wasnt working. its one of the long rectanguler ones :S any one no what globe and how to pull it off with out leaving a trademark or 2 on my front bar :)
https://www.sau.com.au/forums/topic/216195-fog-light-globe/
hey guys, i sused my car lastnight and saw that my passenger side fog light id guess ud call it wasnt working. its one of the long rectanguler ones :S any one no what globe and how to pull it off with out leaving a trademark or 2 on my front bar :O
Hey dude,
I asked this a while ago - have a read here:
http://www.skylinesaustralia.com/forums/Fo...16#entry3689116
ohh, and to not leave a trademark, I used a cloth over the scredriver... :)
Edited by FULOCK
https://www.sau.com.au/forums/topic/216195-fog-light-globe/#findComment-3819735
This topic has come in very usefull and is good timing..I was looking at my car yesterday as was wondering how the hell I would replace the front indicator globes (if they blew)...my stag has a dolphin front bar so it looked like I would need to put it on a hoist to get behind the bar....now I know they can be accecssed from the front...my fog light dont work either ..so I checked the fuse..it is there..so I guess the wires may be cut..will check it out soon...has anyone elst got their fog lights going?
https://www.sau.com.au/forums/topic/216195-fog-light-globe/#findComment-3820465
a mate had his disconected at compliance so mayb just cheak there actualy plugd in :S sounds simple but it was the case for his... but for now the passenger wont get to see threw the fog :P
https://www.sau.com.au/forums/topic/216195-fog-light-globe/#findComment-3820487
On my car they turned out to simply be blown globes,
I could have swarn that they weren't blown when i first checked them.
No wires seemed to be cut or anything..... fuses all there.....
so I bought a new set - plugged them in.... and Bob's your Uncle!! (or Aunty...... which ever way he swings... :down: )
https://www.sau.com.au/forums/topic/216195-fog-light-globe/#findComment-3821300
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
