hey guys.
my car is almost ready to hit the road again.... but first it needs a new ECU.
with the mass amount of options i thought it would be easy. until i remembered....... its an RB20
the car is an RB20DET Cefiro
RB20DET
Garret GT3040R
Custom Plenum
Full exhaust
Front mount
Walbro pump
ive just purchased an Emanage blue but im really unsure if i should use this or go something else.
im considering a remap by Unigroup, a microtech or maybe an emanage ultimate
the blue was only $350 including harness (not car specific ) so im not to worryed about not using this.
please give me your opinions. also please no Power FC propaganda. i no RB26 FC's can be rewired but i dont want to be going into something blind.
i only want to spend my money once, for the time being anyway. and want to get the most out of the car.
cheers guys and gurls
Mick.
https://www.sau.com.au/forums/topic/216266-rb20det-ecu-what-on-earth-do-i-get/
I'd go for a remap too...just make sure you go to someone who knows what they're doing...tonnes of guys here have gotten great results with remaps on their rb20s...only drawback is that it limits your choice of tuners...if cash is no issue then maybe a PFC can be considered too...
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
