I just put in on of sydneykids front sway bars and all seems good except it seems to move in the horizontal direction and not stay central. This in turn causes the swaybar to touch and scrape the subframe as it flexes which is loud and anoying as hell!
I have done up the d bushes tight aswell. What else can i do? it seems the stock swaybar has thought about this as there is a flat section in the bar and this point whereas the shelley bar is all uniformly round throughout untill the ends.
please help i have a track day tomorrow and i dont want to have to put the stock swaybar in!
https://www.sau.com.au/forums/topic/216269-front-swaybar-troubles/
it shouldn't be moving horizontally at all! It should only twist.
do you have a pic of the point where it's catching and a couple showing how it's sitting under the car and at the wheel?
Just to address r338oy's comment. Whiteline really need to take a long hard look at their QA because i've seen a few examples that should not have made it out of the factory. A mates s13 that is maybe 20mm lower than stock has all of 80mm ground clearance due to the front sway bar being the wrong shape.
yeah, but it shouldn't. It is only supposed to twist. The links at the wheels should be vertical (well sort of when you are playing with adjustable bars) They shouldn't be pulling the bars sideways. If they are then the bar is f**ked and should be returned as it's been made wrong.
Thats why i asked for pics. To ensure you have it installed right and not pulling it one way or the other
Swaybars moving laterally usually indicates some form of geometry problem with the car. Swaybars are usually self aligning, they centre themselves with even loads from each wheel. If it is consistently one way then that is a strong indication that something is not aligned with that particular car. My first suggestion would be to check for what it is that is causing the bar to be pulled one way not the other. Uneven ride heights, bent links and worn control arm bushes are some of the more common reasons.
There are lateral lock kits available which clamp on the bar adjacent to the D bushes and prevent the bars moving sideways. This is becoming more common on late model cars, for example 350Z's, V35's and M35 Stageas have lateral locks on their standard bars. PM me for details, they are not expensive and work very effectively.
Cheers
Gary
That's unusual, it always pays to check the bar part number, it should be on a label on one arm of the bar. Lots of Nissan swaybars are almost interchangeable, perhaps someone who should know better has sold him an "equivalent". Whiteline will exchange any bar incorrectly supplied and retrain the relevant sales person if necessary.
Cheers
Gary
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
    • @silviaz Ok cool, so much easier with a video. I can see why this video would be confusing for new players.   It is obvious that this entire bonnet is going to be resprayed, have a look in the background around 2:05, you can see a bunch of bare metal on the left side of the bonnet.  It's not an issue for the primer being laid down on the non-prepped clear on the bonnet. It will be sanded off at a later stage.  This might not be obvious to new players, but working on bare metal and factory paint in this instance, the factory paint is like a mountain and the bare metal is a huge valley. The bonnet needs to be levelled flat before it receives it's final stage of colour and clear coat. During this levelling process, the primer that is landing on the clear that you are worried about will be removed.  Also, this guy is out of control. Zero PPE while spraying, maybe he is a good example overall about what not to do lol.
    • Ok I FINALLY found a video lol. This took way longer than it should have as I could have sworn I saw multiple videos like this. I kept finding the completely opposite (the correct way of doing this). I wouldn't be surprised if I f**ked this up somehow.  I just realised where I've been getting confused and even with other things I work on. I haven't been doing things the regular way instead I'm going a roundabout way of doing things, like putting epoxy primer first then filler for example instead of putting just filler then primer on top of that, then wondering what happens if I get that primer on the clear coat that I haven't sanded yet. This was a bit of an epiphany 馃槀  But anyways, here this video. Time stamp, 2:56, some of the primer lands on the paint unscuffed above. You can see from the reflection it looks shiny.
    • It does, this part circled in red. I assume the OEM bolt might not work well with the poly bushing because the dimensions may be different?
    • The J arm doesn't have bushes either. Assuming that by "J arm" you mean the part of the upright that runs down from the upper arm's outer bushes to the top of the hub. That has a kingpin style bearing in it. If you meant the lower control arm, it has 1 bush, at its inner end. If you have PU in there, that is superior to Nismo rubber. If you meant the caster/tension rod - it has 1x bush at the front end, and again PU is superior to Nismo rubber. But as I said above, I would definitely get the GKTech arms for that, as sphericals slay all other options there.
