Make:nissan
Model:s13
Milage:0km
Transmission:5sp manual
Colour: white
Complied? yes
RWC supplied? no
Currently registered?no
Price:$11,500 or swaps(cash adjustments if needed)
Contact:0403 880 106
Comments / Modifications:
BODYWORK:
*35mm wide fibreglass gaurds
*50mm read gaurds with petrol cap flush
*Full BN flare kit with au style grill
*Euro tail lights
*M3 style mirrors
*Vented carbon firbre bonnet painted black with awesome purple pearl.
*full respray in Tinter white with ice Blue flake
*rollin on 16" wheels
*Sunroof
INSIDE:
* Climate control/air con
* Clarion cd player/mp3 player
*6x9's and 6" speakers
* 2 gauges in dash
*all interior is in perfect condition no marks
*pwr windows all work/electric sunroof
ENGINE:
*Fully built and balanced motor/crank
*block has been bored 40thou, machined and prep'd
*ACL 40thou Forged pistons/rings/pins
*Scat H-beam forged rods with ARP rod bolts
*ACL race bearings allround
*new water pump/timimg chain/guides/pulleys/engine mounts
*ARP head studs/main studs
*New oil filter/greddy plugs/oil/fluids
*tomie rocker arm stoppers
*.8mm commetic head gasket
*head has been machined and cleaned
*Plenum
*Bosch bigger throttle body
*SS High mount manifold T3 flange
*To4 with a .63 exhaust housing
External waste gate with screamer pipe
*BOV
*600*300*100mm intercooler brand new, alloy piping
*Full 3"zausht with a cannon
*oil catch can
DRIVELINE:
*5 speed SR20 gearbox
*Never used NPC organic clutch 2800pound clamp pressure
*short shifter (disconnected still available)
*lsd Diff
*has lowered pedders springs all round
*also adjustable tie rods
*new pwr steering pump
FUEL/COMPUTER:
*550hp fuel pump
*Rising Rate fuel reg
*standard ecu/ injectors
*Custom polished fuel rail (disconnected still available)
*880cc MSD injectors (disconnected still available)
also add battery has been relocated to boot.
*Can view the car running, Has just been on the dyno to double check.
Runs great but just needs aftermarket ecu to handle the modifications.
Compression test came back 150 all 4 cylinders
Images:
i don't know what the either....
i was just going through my old posts, looking for another one, when i stumbled upon that.
not quite sure what happened there.
umm, free bump? :down:
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
