what oil restrictor you running? we run a 1mm and a tomei baffle (and twin oil coolers) with no issues in our drift car which see's 8000rpm for long periods of time.. that high octane sump was on the cards but requires to many mods to clear the sway bar setup in our car :D tis a real nice piece of gear
https://www.sau.com.au/forums/topic/216331-sump-extension/#findComment-3821922
Ok will take some snaps in the next day or so.
And running a 1mm restrictor on the new engine which was startred for the first time wednesday so will be a few weeks before we get on the track in anger. Still have not found the reason for engine failure yet so it a slowly slowly approach.
Its a time consuming job to work out the mounting and cutting out the sump to fit it but good news its quite good quality cast alloy so it welded up a treat. Recomend that you bolt the sump to and engine block while its welded and let it cool before removing it so it dont warp. Mine came out perfectly no twisting or leaks yet
https://www.sau.com.au/forums/topic/216331-sump-extension/#findComment-3822096
Here are some pics of my HiOctane sump welded up.
No pics of it mounted as yet!
Sump Extension
Hey Andrew, that's the same Sump Extension I have in my GTR should do the job for you know drama, your using it primarily as a track toy right?
How's the build coming along? And the M? Latest news is Motorsport have got the parts to make the gears and are manufacturing them, availability is scheduled for end of May/ June.
https://www.sau.com.au/forums/topic/216331-sump-extension/#findComment-3829289
yeah it's pretty cool. you mean the one it has on the top right, for the external oil return?
wanna swap dirtgarage? you don't need a nice highenergy one for drag. the trust one I have will be perfect for that!
edit:
fk it, since we are all gathered here today, I may as well whore a few pics of my sump. :yes: not as nice as merlins fancy one but still pretty decent.
https://www.sau.com.au/forums/topic/216331-sump-extension/#findComment-3832927
Hey Ben,
Yep, the only road use this car will see is on its way to and from the various racetracks ;)
Build is getting there! The entire car is stripped at the moment, and waiting for its date with Bond Roll Bars :P Then comes paint, and then I can start driving it! Brakes and suspension will be coming shortly after... They are both jaw droppingly expensive ;) It seems that any parts for cars with GTR or M automatically have a 100% markup :laughing-smiley-014:
https://www.sau.com.au/forums/topic/216331-sump-extension/#findComment-3834552
Hey Ben,
Yep, the only road use this car will see is on its way to and from the various racetracks :D
Build is getting there! The entire car is stripped at the moment, and waiting for its date with Bond Roll Bars :banana: Then comes paint, and then I can start driving it! Brakes and suspension will be coming shortly after... They are both jaw droppingly expensive :ban: It seems that any parts for cars with GTR or M automatically have a 100% markup :laughing-smiley-014:
Hehe yeah I hear you, gets expensive!
What route are you going brake wise?
https://www.sau.com.au/forums/topic/216331-sump-extension/#findComment-3838951
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
