Kkr 430 Potential? Will Screamer Bolt On It?
do you have an SR20? either way I am running a trust T518Z on my SR20 it's currently making 226rwkw on about 16/17psi (from memory). pulls very hard and comes on very nicely. great little turbo.
Got an rb20 but taking my time to decide what to do with it before dropping it in my s13.
  • 4 months later...
i can see that most ppl dont think much of the kkr brand... im looking at buying another cheaper turbo brand this weekend and wanted to know what u thought about it.......
kkk k27 hi-flow turbo, T3 flange, pretty sure its a .63 compressor housing, made 320rwkw on an rb20det
HKS 38mm wastegate in excelent, came off the same combo as above
would be buying both,would this be a good set up on my r33?
i have a full 3ich exhurst, front mount, pod, fuel pump, greddy boost controller, and emange ultimate on the way and will be buying bigger injectors very soon
any advise would be great
Edited by fandango
When my hi-flow turbo decided enoughs enough, I went searching for upgrades also.
I saw the kkr range and thought, cheap! looked into it more and more. the more I looked into it, I saw people had them replaced again and ended up costing more in the long run. So I decided on the hks GTRS turbo kit.
i run kkr480 with 50mm external gate and done nearly 25,000kms on 19psi no shaft play not a drama with it.. u buy the cheap knock off brands u will get nothing but shit, buy from otomoto and ull get a proper balanced decent turbo. my 2 cents anyway
I too have a KKR 480, RB25 and a Microtech which is tuned richly, mine is a constant headf**k of exhaust leaks, and a mate with a HR31 running a stock RB25DET NEO with a GT2535 (running stagea stock computer too lol), chomps mine all the time.
Its not so much that its laggy (but I reckon a BB turbo would be a fair bit less so), more that it feels like you've got to wring the car's neck to get it moving, and it seems that mine hits around 15psi or so and you can't feel it really pulling anymore (could have something to do with extra kerb weight though lol). I have heard that they have a fair bit of improvment with external gates however. I'm also sceptical about the longevity with these turbos.
Edited by bozodos
  • 4 weeks later...
Hey mate, i had a KKR 430 on my rb20 and it pulled 297.5hp atw, Great fun to drive with cause it kicked in hard, but it is laggy. I am selling my turbo kit right now as i have put in a 26.
For $1200 ONO plus shipping ill sell u my kit which comes with:
-KKR430
-Highmount manifold
-External wastegate
-Cooler piping (no BOV)
-3" Dump with near new o2 sensor
-Oil line (custom)
So all u need to get it running is a BOV, FMIC and about a couple of hours to fit and weld up the dump to ur exhaust.
I bought everything new and i have only had it on the car for about 6 months. The turbo it self is in great condition, and has had the gate welded shut.
Drop as a msg with your email if u want to see any pics of it all.
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
