I was told [note not me, but told] that the stock BOV will not cleanly handle the extra flow. But there are several shops that will mod your std BOV so that it can, mine was done when I installed the GT3076. Its no bling bling bright thing, it looks bog stock [which I think is good], but so far it has worked. And the mod didn't cost the $400 a HKS/Greddy etc BOV costs [it may not sound as good either, but I DGAF about sound].
Others on here may have different idea's.
you sure stock one?
if so i wont bother with purchasing one...
  • Replies 66
Posted Images
they would of stuck the bov in the vice lol
the stock bov has been proven to hold over 300rwkw, you should be fine.
will my stock bov be up to the task if i am to run 17 psi on this turbo?
ive been quoted on a turbosmart full plumback bov. for around 400
what is a cheaper option regarding plumback bov's?
The cheap version is either getting a GTR BOV, it should handle up to 18psi, or getting the gtst BOV diaphragm spring compressed/replaced with a higher tension spring so the BOV doesn't leak under ginormous boost. That's bloody cheap.
Too right. If it works, is legal, cheap, effective and if bling isn't required- what's there to criticise?
