downhill32 Posted April 25, 2008 Share Posted April 25, 2008 hay all, my problem is i recently installed a boost controller and wound my turbo(stock) to 12.5psi.now when full boost hits somewhere between 4500-5000rpm the exhaust starts to make a poping sound and the car starts to miss fire(wont pull anymore).my car is a r32 gtst with a full exhaust,fmic,chipped ecu,pod filter.my thoughts are that it could be one of 4 things the coil packs which i checked today seem ok,the spark plugs, or that the injectors or fuel pump is maxing out, any help would be great. thanks Link to comment https://www.sau.com.au/forums/topic/216410-need-help/ Share on other sites More sharing options...
The Mafia Posted April 25, 2008 Share Posted April 25, 2008 you've solved your own problem - I bet your plug gaps are not 0.8mm Link to comment https://www.sau.com.au/forums/topic/216410-need-help/#findComment-3822539 Share on other sites More sharing options...
downhill32 Posted April 25, 2008 Author Share Posted April 25, 2008 thanks will try that tomorrow,can you do it yourself or do you need a mechanic to do it? Link to comment https://www.sau.com.au/forums/topic/216410-need-help/#findComment-3822569 Share on other sites More sharing options...
nizmonut Posted April 25, 2008 Share Posted April 25, 2008 got some feeler gauges, ???? Link to comment https://www.sau.com.au/forums/topic/216410-need-help/#findComment-3822764 Share on other sites More sharing options...
Roy Posted April 26, 2008 Share Posted April 26, 2008 An R32 GTSt with a good exhaust, intercooler and air filter will basically make 12psi without a boost controller. Was that eh case? If not then you could have another problem Link to comment https://www.sau.com.au/forums/topic/216410-need-help/#findComment-3824016 Share on other sites More sharing options...
zero'sR32 Posted April 26, 2008 Share Posted April 26, 2008 actuator for r32 turbo is at 10psi.. so wont really go to 12 unless its really cold... u will need to regap ur spark plugs.. takes an hour out of ur time... ive got mine down to .65mm works a charm Link to comment https://www.sau.com.au/forums/topic/216410-need-help/#findComment-3824172 Share on other sites More sharing options...
nizmonut Posted April 26, 2008 Share Posted April 26, 2008 10 bucks says your coils are on there way out Link to comment https://www.sau.com.au/forums/topic/216410-need-help/#findComment-3824729 Share on other sites More sharing options...
