This may be a dumb question, but here goes. I don't really understand how wastegates work completely. I know they control boost by letting off exhaust gas before it gets to the turbo. Here is what I don't understand. If you have you wastegate spring or whatever it's called set to .8 bar and your boost controller set to 1 bar how does that work? What does the spring in the wastegate do? Also if you have a .8 bar spring can you boost lower than .8bar? say .5bar? Thanks
https://www.sau.com.au/forums/topic/21643-question-about-wastegates/
The spring in the wastegate is the minimum boost you will be able to run...
Then the boost controler (manual or electronic) just bleed or control the boost line going to the actuator, therefore it won't open until the boost controler send the a boost value to the actuator that is equivalent to the spring in the wastegate actuator.
The problem...is with a 10 psi spring, even if you unplug the wastegate actuator pressure line, it will start to open by itself at a certain boost pressure cause the exhaust flow become strong enough to make it open slowly..and then you have reached the maximum boost for that actuator!
I had that problem on my SR20DET, I couldn't boost more than 16 psi cause of the actuator...I was on my way to put a stronger spring (stock actuator is 7 psi) but I blew my engine before that :D
  • 4 years later...
hmm i was also intrested in this because i don't know alot about turbos and wastegates except for the basics .. so.. say you have a 14psi spring can you run at 20psi using a boost controller.. because ive been looking around and the max spring i could find was 22psi what if you wanted to run 30 psi..
thanks
If you put a 1.2bar spring in your waste gate the minimum boost you will be able to set your controller to is 1.2bar. If you are going to be running high boost pressures you are better off running the higher spring rate as it will control boost far better than a .8 bar spring.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
