This may be a dumb question, but here goes. I don't really understand how wastegates work completely. I know they control boost by letting off exhaust gas before it gets to the turbo. Here is what I don't understand. If you have you wastegate spring or whatever it's called set to .8 bar and your boost controller set to 1 bar how does that work? What does the spring in the wastegate do? Also if you have a .8 bar spring can you boost lower than .8bar? say .5bar? Thanks
https://www.sau.com.au/forums/topic/21643-question-about-wastegates/
The spring in the wastegate is the minimum boost you will be able to run...
Then the boost controler (manual or electronic) just bleed or control the boost line going to the actuator, therefore it won't open until the boost controler send the a boost value to the actuator that is equivalent to the spring in the wastegate actuator.
The problem...is with a 10 psi spring, even if you unplug the wastegate actuator pressure line, it will start to open by itself at a certain boost pressure cause the exhaust flow become strong enough to make it open slowly..and then you have reached the maximum boost for that actuator!
I had that problem on my SR20DET, I couldn't boost more than 16 psi cause of the actuator...I was on my way to put a stronger spring (stock actuator is 7 psi) but I blew my engine before that :D
  • 4 years later...
hmm i was also intrested in this because i don't know alot about turbos and wastegates except for the basics .. so.. say you have a 14psi spring can you run at 20psi using a boost controller.. because ive been looking around and the max spring i could find was 22psi what if you wanted to run 30 psi..
thanks
If you put a 1.2bar spring in your waste gate the minimum boost you will be able to set your controller to is 1.2bar. If you are going to be running high boost pressures you are better off running the higher spring rate as it will control boost far better than a .8 bar spring.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
