Hi all
friends i have bad problem naw my rb25det build boost in nutral gear with stoped car
i heard that RICH & RETARD so i changed AIRflow METER 4 times and the mechanic changed the cas
3 times but still same thing can you help me pleas my car stoped i can`t drive it :)
https://www.sau.com.au/forums/topic/216461-rr-problem-without-solution/
Hi all
its also hisitating when driving
Hi dears
i did all this staff till now and about diagnostics i dont have tool
i changed maf 4 times all same result
i changed cas 3 times all same result
i tryed it without intercooler like direct its littel bit ok but small stuk from 5.5k to 6.5k rpm
and today we will try another turbocharger because some garage said if its littil crap will do same problem
so guys if some one have same this damin problem give us some help :thumbsup:
finally i am thinking that could be ignetion coils !!!!! :(
what mods are u running?
crook w/g actuator?
have u done a diagnostic? try resetting the ecu properly(shorting the 2 pins in the plug method)
dear am using stock turbo with stock wastegate but before i changed it i hade rb20det w/g
to gaine 10 psi
this thing start when i put new greedy front intercooler
I think your timing is off, is it being correctly adjusted AFTER you've been changing over the CAS sensors?
There isnt many things that will cause boost buildup in neutral and timing is the big one
Or the gauge could be faulty, put a decent one on there or are you using the stocker? (dont trust the stock one)
UltimateGTR - nothing to do with actutors etc... its not under load in idle plus the gate is closed on idle normally anyhow, so its gotta be fuel related, ie before turbo
no man when we changed the cas we adjust the timing by timing light
even i changed ecu with good one also i changed the coils all do same problem
but when we retaind factory intake manifold problem hapen in 5.5 to 6k
but really how could boost come up like antilage in nutral :banana:
i belive its ignition but where i don`t know
When the timing is set, is the cas near the centre? Your harmonic balancer may have slipped, and your setting the timing very retarded.
yes brother its in center and with timing gun i got like 12 - 13 degres
all my mods now 3 inch exhust and pod filter with greddy intercooler front mont
and gtr fuel pump also i changed the plugs
yestarday we changed the three wires all long from MAF to ecu and the car runs good
but still i have loosing power in 3rd 4rth gear :P
by the way i am going to buy power fc ecu do you agrre with me ? that it will help me too much
and thanks all for help
What you mean the problem happened @ 5500rpm/6000rpm with the factory plenum?
What other parts are changed?
Full listing please
its noticable loss of power that somthing hold your car moments
and my mods are 3 exhust pod filter intercooler gtr fuel pump thats all now
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
