R&r Problem Without Solution
Hi all
friends i have bad problem naw my rb25det build boost in nutral gear with stoped car
i heard that RICH & RETARD so i changed AIRflow METER 4 times and the mechanic changed the cas
3 times but still same thing can you help me pleas my car stoped i can`t drive it :)
Hi all
its also hisitating when driving
Hi dears
i did all this staff till now and about diagnostics i dont have tool
i changed maf 4 times all same result
i changed cas 3 times all same result
i tryed it without intercooler like direct its littel bit ok but small stuk from 5.5k to 6.5k rpm
and today we will try another turbocharger because some garage said if its littil crap will do same problem
so guys if some one have same this damin problem give us some help :thumbsup:
finally i am thinking that could be ignetion coils !!!!! :(
what mods are u running?
crook w/g actuator?
have u done a diagnostic? try resetting the ecu properly(shorting the 2 pins in the plug method)
dear am using stock turbo with stock wastegate but before i changed it i hade rb20det w/g
to gaine 10 psi
this thing start when i put new greedy front intercooler
I think your timing is off, is it being correctly adjusted AFTER you've been changing over the CAS sensors?
There isnt many things that will cause boost buildup in neutral and timing is the big one
Or the gauge could be faulty, put a decent one on there or are you using the stocker? (dont trust the stock one)
UltimateGTR - nothing to do with actutors etc... its not under load in idle plus the gate is closed on idle normally anyhow, so its gotta be fuel related, ie before turbo
no man when we changed the cas we adjust the timing by timing light
even i changed ecu with good one also i changed the coils all do same problem
but when we retaind factory intake manifold problem hapen in 5.5 to 6k
but really how could boost come up like antilage in nutral :banana:
i belive its ignition but where i don`t know
When the timing is set, is the cas near the centre? Your harmonic balancer may have slipped, and your setting the timing very retarded.
yes brother its in center and with timing gun i got like 12 - 13 degres
all my mods now 3 inch exhust and pod filter with greddy intercooler front mont
and gtr fuel pump also i changed the plugs
yestarday we changed the three wires all long from MAF to ecu and the car runs good
but still i have loosing power in 3rd 4rth gear :P
by the way i am going to buy power fc ecu do you agrre with me ? that it will help me too much
and thanks all for help
What you mean the problem happened @ 5500rpm/6000rpm with the factory plenum?
What other parts are changed?
Full listing please
its noticable loss of power that somthing hold your car moments
and my mods are 3 exhust pod filter intercooler gtr fuel pump thats all now
 Share
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
