Hey guys im just about to buy some 18" Work Emotion Cr Kai's.
I need to know what will be the best offset on my R34 Gt-t. I want them to fill the guards as much as possible, but do not want the hassles of having to flare my guards.
the fronts i want are 18 x 8.5 and rears are 18 x 9.5
The avaliable offsets is as the table below,
Thanks all.
Edited by HKS_R34
Give me your current wheel specs and I'll tell you how much each offset will change from the way it sits at the moment.
Everyone's opinion of how 'flush' looks is different.
My current wheel specs are 18x 8.5 and 18 x 9.5 offset +32 (not 100%) tho.
Im running stock suspension at the moment, but will be upgrading to Zeals later down the track.
Front:
18x8.5 +43 will be 11mm more tucked than it is now. Suspension clearance could be a problem with after market coilovers.
18x8.5 +37 will be 5mm more tucked than it is now. Suspension clearance could be a problem with after market coilovers.
The 18x8.5 +30 will be moved out 2mm compared to your current wheels.
Rears:
18x9.5 +38 will be 6mm tucked than current.
18x9.5 +30 will be 2mm moved out.
18x9.5 +20 will be 12mm moved out.
18x9.5 +12 will be 20mm moved out.
You're planning on getting wheels that in the same widths, not hard to just see the difference in offset. If you go to a higher offset, it will be more tucked, lower offset, more out.
If you're planning on running the same tyres, measure the "20mm moved out" from your tyres instead of wheel to see if they touch guards.
Edited by adam-__-
after trialling rims on mates r34 gtt (standards susp and no guard work), if they are the only offset options you have
front: 8.5" +30 (or +25 if you want to really fill the guards)
rear: 9.5" +38 (or +30 if you want to really fill th guards....will need to get the guards lipped if you lower it though)
if you want something that looks decent and isn't hanging outside the guard go 8.5" +30 and 9.5" +38, but any offset higher than this will look sunken in
i got work emotion cr-kai's on my car with the following offsets
front : 5 X 114.3, 18 X 8.5 - OFFSET +30
rear: 5 X 114.3, 18 X 9.5 - OFFSET +38
both side inside guards, car's been lowered to almost rubbing the guards with coilovers too
very nice mate. might go with those offsets.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
