both my r32 & r33 actuators have nipples coming out straight from the side.
not sure if S1 & S2 R33 turbo came with different actuators but what you have doesn't look like R32 one.
R32 turbo has 16V5 on the housing and R33 one has 45V3, not sure if you can determine which series turbo from that.
Edited by sonoramicommando
My friend also has this prob when he installed his 33 turbo on his RB20 using the 32 actuator he only see's 7 PSI now he uses a turbotech boost controller and gets 10. But he still could not figure out why he only got 7 PSI, he did have a front mount if that makes any difference?
you need to measure the pressure where it opens up to really know whats going on, be it R32, R33 or R34 actuator.
im using r32 actuator (measured to open up at 10psi) on r33 turbo and i see 8-9 psi at plenum with stock cooler. the actuator is hooked up to turbo compressor housing.
Hey i just picked up my r32 wastegate actuator about 30 mins ago and i know for a fact that its an r32 wastegate actuator because its out of my mates r32 cause hes doin a rebuild.
Im sorry to tell you fishy but mine doesnt look like yours and i cant tell you what skyline yours is out of.
To best describe mine take a look at your third picture. Mine has the nipple on the opposite end as to the one in that pic and my nipple is straight. The numbers on the actuator read: (ASN79-) which is engraved into the actuator.
It also has stamped to it (241321) and AS VALVE. Hope that helps. ill be installing mine tomorrow morning.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
