Power To 8000rpm Rb20
What would be the best combo to make power to 8000 rpm? What cams at what lift/duration? What sprockets? What turbo? I'd like to make 270-300 whp. I don't care if it doesn't make power until 4000. I like some lag to stay out of boost while cruising. But a 3500-4000 rpm pull range would be nice. If your wondering what I'll use if for that would be fun. Just something to beat on and raise general hell. Thanks
Edited by twofortyrida
You won't need cams to make power up to 8,000rpm
You will need a bigger turbo, injectors, engine management, fuel pump, exhaust, intercooler and tune
Turbo wise something like a HKS2535 would be good if your looking for around 300rwhp and its not that laggy either
ive got the KKR480 turbo... runs about 17psi. bit laggy, full boost by about 4.5k but turbo is still new so gotta let it settle a bit.. but apart from that.. car revs happily to 8500rpm with out so much as a tune yet
i got intercooler, exhaust, gtr fuel pump, remapped ecu and electronic boost controller...
Meh to valve springs and all that. Just get a nice turbo rated at around 400hp, something like a TD06, 3071 etc and get it well tuned with adjustable cam gears. I run a TD06 on a std motor and on plenty of occassions have ran it to a 8,800rpm rev limit with 18psi or so jammed into it. Though i tend to try and run either high revs or high boost, not normally both.
I know what supporting mods are necessary just needed some advice on good combos to utilize. Thanks.
To Adriano
I really have no good reason other than "just because" or the sound and to do it often. At least hit 8k in neutral, 2nd, or 3rd every day till/if it pops(I know I'm a ricer). If it does it can be rebuild. I love the power/sound/revs/price of the rb20. Its perfect for me.
Who here can mod the stock mani to use an ext wastegate? How much? Isn't the 20g what some dsms have stock but uses 3 bolt flange or what ever?
 Share
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
