haha I think I might be mostly talking to myself....but anyway
Tonight the beasts were robbed in the final!
Thieir rock crawler was much better but they lost in the end just because the length of their wheelbase was wrong for where the rocks were. the other guys with the crappy car but longer wheelbase got away with it.
at least that means next episode is one of their champion's challenges which are always godo
This is best show! Except the "junk" they bring in i doubt is real junk since for every episode they always get specific parts in there, so the show places those parts before each episode to make things fair and easier. I miss how in the first episodes none of the engines and batteries could barely work and took ages to get started now it seems they all run fine.
I watched the episode when they built the race cars. Well some of it.
The "expert" commentators were explaining how putting more weight over the rear wheels helped them grip better and caused the car to understeer.
It was at about that point I threw up and left the room.
been watching a lot of episodes on youtube way back from 98/99
they are the best cause the engines dont work properly etc
ahh well there's only so much you can expect from the commentators, it doesn't really take away from the amazing back yeard engineering they do.
jewjitsu I totatlly agree - especially since they moved to the newest scrapyard. I reckon they just have a better bdget these days and they run out of a set, not a scrapyard. every bloody motor or car they pull out these days work
duncan - your a mad dog how you love this show, i recon its cool as well! Def beats watching sport on weekends :thumbsup: Its also cool when they have to use guns i saw one where they had to build a little kind of tank and have to have air guns that shot out potatoes at the other machine it was funny, the commentator were expecting there to be damage a potato shot across like two football fields wouldnt do much lol (hope you could get your head around what i just wrote lol)
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
    • Cheers mate. Seems some people get lucky others don't. It looks like the motor was detonating (to be expected if it was overboosting I suppose) as the pistons had a lot of detonation damage, and the bearings were stuffed. The bores were very scoured too, not sure if that's from the pistons or bits of ceramic turbo. By the by now. Have been trying to avoid the rabbit hole too much on the rebuild, and there's been a few hurdles along the way, but with any luck I'll have the car back soon™. Might even pop up a thread then.
