haha I think I might be mostly talking to myself....but anyway
Tonight the beasts were robbed in the final!
Thieir rock crawler was much better but they lost in the end just because the length of their wheelbase was wrong for where the rocks were. the other guys with the crappy car but longer wheelbase got away with it.
at least that means next episode is one of their champion's challenges which are always godo
This is best show! Except the "junk" they bring in i doubt is real junk since for every episode they always get specific parts in there, so the show places those parts before each episode to make things fair and easier. I miss how in the first episodes none of the engines and batteries could barely work and took ages to get started now it seems they all run fine.
I watched the episode when they built the race cars. Well some of it.
The "expert" commentators were explaining how putting more weight over the rear wheels helped them grip better and caused the car to understeer.
It was at about that point I threw up and left the room.
been watching a lot of episodes on youtube way back from 98/99
they are the best cause the engines dont work properly etc
ahh well there's only so much you can expect from the commentators, it doesn't really take away from the amazing back yeard engineering they do.
jewjitsu I totatlly agree - especially since they moved to the newest scrapyard. I reckon they just have a better bdget these days and they run out of a set, not a scrapyard. every bloody motor or car they pull out these days work
duncan - your a mad dog how you love this show, i recon its cool as well! Def beats watching sport on weekends :thumbsup: Its also cool when they have to use guns i saw one where they had to build a little kind of tank and have to have air guns that shot out potatoes at the other machine it was funny, the commentator were expecting there to be damage a potato shot across like two football fields wouldnt do much lol (hope you could get your head around what i just wrote lol)
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
