  • Replies 54
Thats intresting i think the rta are stuffed in the head. I got defected with a pod but they didn't touch my quite large front mount. I rang the rta to find the legal reason why pods are legal right. They said it effects emissions right. Well far as i know the Air measureing device ie air flow meter as long as the pod is before the sensor the sensor will change the injection rate to suit the amount of air therefore not effecting emissions. Well the rta said i would need to get a engineer to engineer it. Well i asked them if a 3 gas print out for a NSW Blue slip station saying it meets the RDA that would be sufficant and they said no. Well WTF the blue slip stations are ment to have 3 gas annaliser there for rego purposes. But thats not good enough. So i rang the Australian design rule office and they said if i have a 3 gas read out saying it meets the RDA emisson level thats fine. But once again i rang the rta and that wasn't good enough. So i said to they so any air filter that is not a factory one they can defect you it. I think its plain wrong but the RTA needs there revonue.
I just changed back to my standard filter cauze i just put an exhaust on. If i get pulled over now they can only really do me for exhaust and possibly frontmount and not pod filter. Last time i got pulled up with my pod, they wanted to send me to EPA but i never ended up getting the letter. I dont wanna run that risk again. Exhaust is easy to change to clear defect but a front mount cooler is a pain in the ass to take off and put back on.
yup sounds about right, bottom line is they way they see it, any induction of exhaust mod change's the emission level's of the car, therefore possibly no meeting emission's... i got done for an adjustable plumbback bov when i went to clear my e.p.a bullshit, because the inspector said i could adjust it therefore change the emission's......
on a side note, the pod filter thing is also not just about what it would do to the exhaust emission's, theyre also worried about the excessive noise emission's caused by the pod filter, as it no longer has induction silencer's like the std airbox does.
Yep, the 'Emissions' for a POD filter are not gas emissions, but noise emissions, as they change quite dramatically, even with only a POD change.
I have twin PODS on the GTR, and they are LOUD compared to a stock box.
I am in the process of creating a custom box for around the PODs, but we will see how that goes at a later stage :nyaanyaa:
B.
I'm wondering.. You see all those plastic covers on newer model cars these days.. What's the go say if you got one of those fabricated to cover your engine bay, venting in required areas where needed.. What's a cop going to say or do?
Seems like more work than making a good quality air box for less performance gain. Isn't that why you got a pod in the first place?
The requirement is that there are pipes entering the air box, not just holes for vents because that would just be an open box. So there must be perpendicular surrounding tube connected to any vents. It is best to pipe to the outside of the engine bay to get the cold dense air in anyway. So you end up with more efficiency than standard.
I just went through all this last week.
I recieved a notice in the mail that I had 3 weeks to have my car checked at an approved DECC station. (one at Granville, one at Campeltown)
My car was apparently reported by an DECC officer who made the assessment by looking at the car that it may exceed noise limits. (5inch canon) I had it tested by my local exhaust shop where it recorded 99db. The limit is 90db at 4800rpm. The shop made me up a nice quiet cat back system that came in at 87db while I waited.
At the noise test the mechanic took photos of the airbox, exhaust and intercooler. As the intercooler was not standard my options were to have it tested by the RTA emissions people or return it to standard. I figured that it was easier to put the standard intercooler back on than have the test done and run the risk of having to remove boost controllers, APEXi and the like.
Pain in the backside considering I seldom drive the car but it is actually nicer to drive with the standard intercooler (less hesitation) and I can actually hear the radio now when I'm driving.
BTW I took my car to the Campbelltown testing place after speaking to the dropkicks at Granville. The Campbelltown bloke was really helpful despite having to ensure compliance.
Details can be viewed here http://www.environment.nsw.gov.au/noise/vehiclenoise.htm
^^ thats... awesome...
I'm also going through most of this, I'm trying to find the actual WRITTEN law or rule that pertains to pod filters, and what they have to be shielded from, and why... If anyone has it, or can get it, PLEASE let me know...
"Using a refrigeration unit on a vehicle, after a warning has been given, between 8 pm and 8 am on a Saturday, Sunday or public holiday, or between 8 pm and 7 am on any other day (clause 15)"
What the hell does this mean?
I'll get it for you Doof ;)
Its my understanding a standard airbox is there to stop back fires "igniting/sparking" a fire within the engine bay.
I also believe standard boxes keep the induction noise to a minimum.
And from what I've read around the forums/internet. Adding a pod filter changes the amount of air the engine sees. Although the ecu compensates for this with extra fuel, I believe it would still change the emissions, as its all happening at a different time rather then factory settings.
So I would imagine you would have to build and prove that a pod "box" is capable of fulfilling the above while meeting epa/emission standards.
I believes and I have read and I heards no longer interest me... I'm looking for the written information only so we can put an end to the myths once and for all...
But thanks anyway :wub:
I have some ideas about what to do, I just need to know if what I am doing will at all work... I'll wrtie up my findings if the law is ever found ;)
So you guys recommend the guys at cambertown? i to recieved my letter other day. Do we have to pay when we take the car in? also im not to keen on putting standard intercooler back on, how high are the chances of the fmic failing the emissions test?
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
