Hey everyone. I need some advice on tuning my skyline. I have an R32 GTST 4 door Automatic. The RB20DET is essentailly standard except for a larger, Chinease HKS copy turbo (sorry i have no idea what kind :thumbsup: ) and a front mount intercooler. The turbo is laggy but pulls hard when it comes on, but starts to ping at or close to redline. I was told it needed a Fuel Cut defender?. Also there is no boost controller so i think i should get atleast a bleed valve. Also i have a set of GTR injectors laying arround which i would be keen to make use of. How would i do this? maybe Z32 AFM, GTR injectors and a ECU remap from the reading i have done?. Your suggestions much appreciated. Cheers. Mark.
https://www.sau.com.au/forums/topic/216565-rb20det-set-up-advice-needed/
You answered your own question, z32 afm, gtr injectors and a remap..
I would also put a decent fuel pump in there if you haven't already, it's quite likely that your fuel pump is dead and can't supply fuel up top.
Another possibility is that with the bigger turbo you're maxxing the afm, if it can't measure anymore air it stops throwing fuel in and hence leans out.
So, forget the FCD, get yourself an 044 pump or similar installed intank then get the z32afm fitted along with the GTR injectors and have it tuned/remapped, you will notice a HUGE difference :(
Oh and if it doesn't have a full 3" exhaust, put one on :P
Edited by bubba
thanks allot buddy. Fortunately It has a custom 3 inch dump pipe , straight through cat and a HKS super dragger exhaust. I am going to change it to manual soon. So i guess i will get a Manual ECU and get that Remapped and the injectors/AFM put in when i do the conversion. I read in another post that to use the GTR injectors i will need to use a ballast resistor, is this true?. Also would a Mines RB20DET tunes manual ECU suit my needs after a manual conversion?. Many thanks
thanks for the advice everyone. I have a resistor pack and plug here which is lucky. Also some more questions. What will adding the GTR injectors and Z32 AFM with ECU remap do for the engine exactly. Will it allow me to boost more? and stop pinging at redline? maybe reduce lag? should i run any other devices with this setup. At the moment it seems quite laggy its annoying :thumbsup:. The turbo looks quite large, i will get its specs soon . Any suggestions appreciated. cheers
The GTR injectors and z32 afm and remap will allow you to measure more air and whack in more fuel to match the extra air and the ecu remap by your tuner will allow him to smash timing in down low to make it less laggy and tune it properly for fuel/timing on boost (as opposed to a piggyback which is tricking the ECU). Have you got a new fuel pump in there? If you haven't, get yourself an 044 pump or something similar as if the pump is dying it won't be able to supply the fuel the GTR injectors will be trying to throw in :)
  bubba said:
The GTR injectors and z32 afm and remap will allow you to measure more air and whack in more fuel to match the extra air and the ecu remap by your tuner will allow him to smash timing in down low to make it less laggy and tune it properly for fuel/timing on boost (as opposed to a piggyback which is tricking the ECU). Have you got a new fuel pump in there? If you haven't, get yourself an 044 pump or something similar as if the pump is dying it won't be able to supply the fuel the GTR injectors will be trying to throw in :blink:
Thanks for your help in this topic man much appreciated. sounds just what this car needs. I am 80% sure it has an 044 pump . Whats the going rate for a Z32 AFM?.
First on the list though is a manual conversion, then get the manual ecu tuned with the injectors etc.
Here are some specs as it is
1989 R32 Gtst 4 door
RB20DET Automatic
GTR front bar
Carbon fibre bonnet
Currently unidentified chinease hks copy turbo on stock manifold
custom dump pipe
pod filter
F & R strut bars
Xhp 17' wheels
Edited by tstg23r
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
