Hey everyone. I need some advice on tuning my skyline. I have an R32 GTST 4 door Automatic. The RB20DET is essentailly standard except for a larger, Chinease HKS copy turbo (sorry i have no idea what kind :thumbsup: ) and a front mount intercooler. The turbo is laggy but pulls hard when it comes on, but starts to ping at or close to redline. I was told it needed a Fuel Cut defender?. Also there is no boost controller so i think i should get atleast a bleed valve. Also i have a set of GTR injectors laying arround which i would be keen to make use of. How would i do this? maybe Z32 AFM, GTR injectors and a ECU remap from the reading i have done?. Your suggestions much appreciated. Cheers. Mark.
https://www.sau.com.au/forums/topic/216565-rb20det-set-up-advice-needed/
You answered your own question, z32 afm, gtr injectors and a remap..
I would also put a decent fuel pump in there if you haven't already, it's quite likely that your fuel pump is dead and can't supply fuel up top.
Another possibility is that with the bigger turbo you're maxxing the afm, if it can't measure anymore air it stops throwing fuel in and hence leans out.
So, forget the FCD, get yourself an 044 pump or similar installed intank then get the z32afm fitted along with the GTR injectors and have it tuned/remapped, you will notice a HUGE difference :(
Oh and if it doesn't have a full 3" exhaust, put one on :P
Edited by bubba
thanks allot buddy. Fortunately It has a custom 3 inch dump pipe , straight through cat and a HKS super dragger exhaust. I am going to change it to manual soon. So i guess i will get a Manual ECU and get that Remapped and the injectors/AFM put in when i do the conversion. I read in another post that to use the GTR injectors i will need to use a ballast resistor, is this true?. Also would a Mines RB20DET tunes manual ECU suit my needs after a manual conversion?. Many thanks
thanks for the advice everyone. I have a resistor pack and plug here which is lucky. Also some more questions. What will adding the GTR injectors and Z32 AFM with ECU remap do for the engine exactly. Will it allow me to boost more? and stop pinging at redline? maybe reduce lag? should i run any other devices with this setup. At the moment it seems quite laggy its annoying :thumbsup:. The turbo looks quite large, i will get its specs soon . Any suggestions appreciated. cheers
The GTR injectors and z32 afm and remap will allow you to measure more air and whack in more fuel to match the extra air and the ecu remap by your tuner will allow him to smash timing in down low to make it less laggy and tune it properly for fuel/timing on boost (as opposed to a piggyback which is tricking the ECU). Have you got a new fuel pump in there? If you haven't, get yourself an 044 pump or something similar as if the pump is dying it won't be able to supply the fuel the GTR injectors will be trying to throw in :)
The GTR injectors and z32 afm and remap will allow you to measure more air and whack in more fuel to match the extra air and the ecu remap by your tuner will allow him to smash timing in down low to make it less laggy and tune it properly for fuel/timing on boost (as opposed to a piggyback which is tricking the ECU). Have you got a new fuel pump in there? If you haven't, get yourself an 044 pump or something similar as if the pump is dying it won't be able to supply the fuel the GTR injectors will be trying to throw in :blink:
Thanks for your help in this topic man much appreciated. sounds just what this car needs. I am 80% sure it has an 044 pump . Whats the going rate for a Z32 AFM?.
First on the list though is a manual conversion, then get the manual ecu tuned with the injectors etc.
Here are some specs as it is
1989 R32 Gtst 4 door
RB20DET Automatic
GTR front bar
Carbon fibre bonnet
Currently unidentified chinease hks copy turbo on stock manifold
custom dump pipe
pod filter
F & R strut bars
Xhp 17' wheels
Edited by tstg23r
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
