ones im lookin at gettin are adjustable ride height, pre load and 5 stage damper settings. will they be ok in my car? only do track days every now and then and i have nismo coil overs in back? wat think?
brett
Being 4wd, the GTR's have around 180 kgs more weight in the front, so the chances of the spring rate being too high for a 2WD are pretty much guaranted. Plus Cusco coil overs are well known for having higher than ideal spring rates even in the car they are designed for. So the chances of the spring rates being too high are now doubled.
The only way to be sure is to confirm the spring rates with the guys selling them. If he doesn't know, this thread tells you how to measure them and I can then work out the spring rates for you.
http://www.skylinesaustralia.com/forums/in...showtopic=79157
If the spring rates are too high then the shock rates will similarly be too high. In typical Cusco fashion, the adjustment on the shocks will most likely only do rebound (extension) and will have no effect on the bump (compression), so softening the shocks will achieve very little in improving the handling and/or ride comfort.
Cheers
Gary
spring rates for the front on the cuscos is 12k. way too firm for a 33 gtst or will they be ok?
thanks for the help!
brett
Too firm for the track, way too firm, that's almost double what R type tyres will tolerate. In fact it's more than we run on the race cars with full slicks.
Cheers
Gary
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
