Due to my white r33 gts4 being written off, the complete car is up for wrecking, all parts from the engine back are available.
The car has had a rb25det conversion out of a stagea and a 5 stud hub conversion using r33 gtr hubs. diff and diff gears. Also the brakes have been upgraded to r32 gtr brake.
Engine, gearbox, diffs, brakes, suspension will be available soon
Below is a list of items for sale; (probably missed a few items)
EXTERIOR
Shell - offers? The front left suspension strut has shifted towards the firewall (5mm), also there is a bend in the pillar above the passangers door, Front the engine forward has been destroyed and where the gearbox boot is mounted has bent. See photos.
Veilside side skirts (white) - $100 for both Slight damage but easily repairable. See photos
Veilside rear bar (white) - $100 Slight damage from being winched onto the tow truck See photo
Taillights (white) - $100 for both Slight paint damage, includes working globes See photo
White skyline bit - $50
GT badges - $10
White skyline boot lock - $50
Doors complete – $200 each
Boot with drift wing (maroon) - $300
Fuel flap lid -$10
Electric mirrors - $50 each
Wipers - $100 for all 3 finished in carbon fibre paint
INTERIOR
Instrument cluster - $100
Climate control unit - $60
Gear box surround with white gear boot finished, in high gloss black, includes cig lighter and ash tray - $50 Also have drivers and passengers side door plastic bits in high gloss black $100 for the lot
Dash surround with clock etc - $80 Have started to peel back the rubber coating ready to be painted
Centre console - $50 includes handbrake boot.
Door trims $50 each excellent condition
Floor carpet - $100 excellent condition
Seatbelts, buckles full set - $100
Headlight stalk - $20
Steering wheel surround plastic - $30
Ignition surround plastic bit - $20
Glovebox - $30
Rear parcel shelf - $50 includes speaker covers
Complete boot interior - $80 The bit that covers between the headlights is damaged, the rest is fine.
Electric aerial - $50
Rear wiper motor - $30
Space saver 4 stud - $50
Jack and wheel changing gear - $30
Front seats $150 each or $200 both Perfect condition
Rear seat - $100 perfect condition
Factory skyline car mats - $150
AFTERMARKET
C’s short shifter - $150
Bosch 044 fuel pump - $150
Nismo 320 dash - $600 has never been used only taken out of the box once to check connections
Clear front bar indicators - $50 never been used
White nismo duracon gear knob - $50
5 month old Work emotion xt7’s in grey 18”x8.5 +32 with bridgestone Potenza re01 235 all round, includes light weight wheel nuts - $2000 Front left tyre has minor damage.
Pioneer Car audio system, includes 4 speakers, dual din headunit (cd, mini disc), car computer, cd stacker, mini disc stacker, tv - $400
Sard turbo timer - $50
Speco boost guage - $50
Autometer boost, afm guage and pod - $120
leather momo steering wheel with boss kit - $150
Sealed lead acid battery - $100
unknown strut brace - $50
afm sensor - $20
Items available from Kellyville, Sydney
Michael 0402168896
https://www.sau.com.au/forums/topic/216632-wrecking-white-r33-gts4-sydney/
  • Replies 192
Posted Images
Update on parts:
gt badges - sold
boot interior - sold
steering wheel plastic surround - sold
plastic between steering wheel and pedals - sold
high gloss plastic bits, centre plastic bit with clock, gearbox surround - sold
cheers,
Michael
Edited by specialk
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
