  • Replies 192
as per discussions earlier really interested in changing my gearing to GTR spec
and i take it the belts are 100% no frays what so ever and is it easy enough to change buckles
Yeah no change as such required, just had the old ones machined.
yeah keen on belts just looking into what i need to do to take my buckles off and just swap belts
sorry if im harping on about this but my limited knowledge of diff's is possibly proving to be a downfall
it was my (maybe misguided) belief that if i wanted to change final drive ratio's i would need to match to front diff to what the rear diff is running
so i dont get how you have done it so cheaply maybe you might like to PM me with what i would need to complete such a job and i wouldnt be doing the work just informing the tuner what needs to be done
UPDATED PARTS LEFT
momo steering wheel with boss kit - $70
speco boost guage - $10
roof handels - $5
hose clamps (10) - free
indicator/light stalk - $5
foot rest - $5
glove box - $5
ac unit - $50
centre console with white hand brake lever - $30
seat belt set - $20
interior plastic around rear window - $10 all bits
kick panels - $10 ea
stock dash with 115337km - $50
door trims - $20 ea
roof carpet - $20
works emotion xt7 Multistud 4/5 18”x8.5 +32 with bridgestone Potenza re01 235 all round, includes works light weight wheel nuts- $1300
dashboard - $5
bilstien suspension with sway bars and drift pinapples - $1200
gtr gearbox - $500
rb25det out of stagea (has sump with front diff gtr 4.11 gears) turbo, computer and loom - $1500
front right and left plastic mud guards - $10 ea
front windscreen plastic bit - $5
cheers,
Michael
UPDATED PARTS LEFT
roof handels - $5
foot rest - $5
glove box - $5
ac unit - $50
seat belt set - $20
door trims - $20 ea
roof carpet - $20
dashboard - $5
gtr gearbox - $500
cheers,
Michael
what momo wheel is it i need a boss kit so im interested in the whole lot as i cant get my horn working with my wheel
im told i have hicas boss kits :P
and does it align up straight as the 2 kits i have dont :laugh: :laugh:
and does it align up straight as the 2 kits i have dont :blink::P
Unsure of model, but is all black, approx 30cm dia and has 2 inbuilt buttons. One at 3 o'clock and the other at 9 o'clock.
Lines straight with the boss kit
  • 1 month later...
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
