Hi everyone
Im getting rid of a Holden Gemini for a family friend. It has been with them since 1987. Details as follows.
1984 Gemini SL
Manual
290.000kms
Blue/Grey Colour
Rego until end of July '08
General Info:
It is far from perfect but has been a reliable car for over 20 years. The paint is is need of attention, as is the rear drivers tail light. Minor surface rust in the usual places associated with older cars such as in the boot sill area and slight surface rust on the roof etc. The engine leaks oil quite a bit and has been doing so for a while and not caused any problems so far. Tyres are fairly new with plenty of tread left on them. Interior is as expected, pretty old and dirty, with worn out carpet and so on. Its CHEAP!!!
Looking for $800 or offers
Located about 30mins south of Sydney.
Contact:
0400 379 599
[email protected]
PM
Cheers
Ben
https://www.sau.com.au/forums/topic/216649-1984-holden-gemini/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
