Hi everyone
Im getting rid of a Holden Gemini for a family friend. It has been with them since 1987. Details as follows.
1984 Gemini SL
Manual
290.000kms
Blue/Grey Colour
Rego until end of July '08
General Info:
It is far from perfect but has been a reliable car for over 20 years. The paint is is need of attention, as is the rear drivers tail light. Minor surface rust in the usual places associated with older cars such as in the boot sill area and slight surface rust on the roof etc. The engine leaks oil quite a bit and has been doing so for a while and not caused any problems so far. Tyres are fairly new with plenty of tread left on them. Interior is as expected, pretty old and dirty, with worn out carpet and so on. Its CHEAP!!!
Looking for $800 or offers
Located about 30mins south of Sydney.
Contact:
0400 379 599
[email protected]
PM
Cheers
Ben
https://www.sau.com.au/forums/topic/216649-1984-holden-gemini/
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
