Should have the sticker at the back or if you look under the car from the back it should have finned looking diff coolers. Theres probably more but thats all i know. I have a R34 Vpec and is worth the little bit more..
https://www.sau.com.au/forums/topic/216656-r33-gtr/#findComment-3826075
QUOTE
Vspec has active LSD (a yellow light in the dash)
Vpsec has the faster attesa computer 1/1000th of a second rather than 1/100th (not visually noticable)
Vspec has stiffer suspension stock 10mm lower (not visably noticable)
brembos
10kg more weight (not visably noticable)
A Vspec sticker
Air difusers for the front brakes
Slightly better ABS (not visually noticable)
Finned rear diff
https://www.sau.com.au/forums/topic/216656-r33-gtr/#findComment-3826475
thanks for the help. guys gonna pick the car up in a coupla days (bought it any way!) im pretty sure it had fins on the diff housing but thats all i can say for now will check the other things when i get it home and get back with a chassis number etc
thanks again
Burkey
https://www.sau.com.au/forums/topic/216656-r33-gtr/#findComment-3827940
I don't get the point about brembo's, R33 GTR's have them too...
Also the "finned" rear diff is an electronically controlled viscous diff, NOT a mechanical diff like normal GTR's. ie. very expensive if it breaks...
https://www.sau.com.au/forums/topic/216656-r33-gtr/#findComment-3828432
