Dude if It did not do it b4 the BOV check the plumbing is not leaking for this. John W had a similar problem, was firing the spark, down the sides of the plug, not directly at the plug, either way get it checked out could not recommend Dave at Gastune highly enough!
well I did take it there.....they said they could not find anything.
then I found out (on another forum) that there was a little solinoid that adjusts boost. 1 to 5 RPM- 5PSI then 5 to 7RPM- 7PSI. I bypassed it and found it stutters whenever it gets passed 5PSI see if I dont floor it, it wont stutter (from idle all the way to red line). as soon as it gets past 5 PSI does not matter at what revs (3 to 7RPM) it will stutter like hell. by the way the solinoid is near the wastegate (connected with pipe). anyone help?
it's so bad that in a drag I just beat a standed ford falcon.
does this suck or what. I even had all the plugs and timming belt changed ($600) but still nothing. I really think it's my air flow sensor....see when me and my friend left the AFS unpluged it did the same thing....though it done it as soon as it hit boost.
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
