Ok I'm pretty new to electronics/fixing my own car etc so this was a new experience for me
Ok so here's the situation..
My CA18DET decided out of nowhere that it didn't want to start last night..
Originally I thought this was becuase, I was low on fuel and parked in a street which sloped to the left heavily.. So all the fuel was drained away from the pump??!
After repeated attempts to start it and no luck I pushed it onto flat ground where it still didn't want to start.. Next enters christian.
Christian from ns.com came over to help.. After alot of testing he managed to start the car after removing a spark plug. He then thought there may have been some sort of over fueling in the cylinder which needed to be released via removing the spark plug I think while starting the car..
Now anyway, after we got it running I went for a simple little drive and everything seemed fine, stopped at service stations and restarted like normal too..
Now all of a sudden today the same problem has occured and it doesn't want to start..
Thing I have done to try and fix this..
Checked spark plugs ( they seem pretty f**ked/fouled - Quite heavily burnt in areas and all grey/black around the spark part. White paint/stuff leaking from the top.
Checked and found I have no or very little coolant
Did a self diagnosis with the ECU (it's a mines ecu)
Got fault code 13.. engine temperature sensor circuit wiring fault
This supposedly can result in Ecu engine stalls, lack of power, low economy.
Tried again a few more times, and kept getting 55.. ( No problems..) NO PROBLEMS?!! it won't start!!
Now whether that was because I accidentally deleted any fault codes by accidentally going to mode 4 is out there, but i'm 99% sure i didn't accidentally enter mode 4..
Also, when Christian managed to start the car, he found that if he moved the wiring for injector 2 or 4 the car would idle really rough and also want to stall..
Now.. The conclusions..
There is a spark..(tested with a screwdriver) , There is fuel, there is ignition, but there is no magic..
So here's what I've come up with..
1. Stick with fault code 13.. Because I still have zero/no coolant.. Thus, if coolant is dispersed around the engine to control heating, and there is no coolant, perhaps the ecu is detecting this and not letting the car start?
2. Bad/fouled spark plugs resulting in a difficult start, each faulty spark plug is resulting in a 25% reduction in power.. Thus maybe making the car difficult to start.. (But we did get a spark with the screw driver test, so i'm unsure of this one)
3. Some sort of issue with the injectors and/or injector wiring perhaps something grounding?
4. Take out all the spark plugs and try to start the car to drive out any unburnt fuel which may be flooding the cylinders? (put em back in and restart) (Should I try this???)
Any help is greatly appreciated guys.. I'm just trying to narrow it down to save myself money when/if I need to send it into a shop.
https://www.sau.com.au/forums/topic/216674-ca18det-wont-start/
yes, i would definately replace those plugs. they fire with a screwdriver, but maybe not so good under compression. for the love of GOD, fix that coolant leak and get some antifreeze/coolant in there lmao.
The ecu only uses the temp sensor to determine how much fuel the car needs. ie.... when the car is cold it needs to give more fuel, thats why you get a high idle at startup. There is a different sensor next to that for your guage.When the car reaches operating temperature it reads the oxygen sensor to see the difference from the air inside the exhaust and outside the exhaust so it knows whether to enrich or lean. That is called closed loop operation. You will actually know when it is checking when your thermostat opens, the cool coolant hits the sensor and signals to your computer to switch on the electric fan.
Your fault code is telling you that your coolant is low. it will not read when it is dry so it knows your out of coolant.
ahhh thankyou very much for the info, I'll give the sparkies a go tomorrow!
edit: PLUS coolant lol
Edited by ignuz
Replaced spark plugs. Still won't start lol..
Going to be checking the exhausts temperature circuit wiring now as that was the initial fault code I got.
Well that fault code was bogus.. Chucked in the factory ECU after push starting the car.. Drove around for a while and got the fault code I needed.. ignition signal missing in primary coil wiring fault.
problem found :D
lil secret with the CA's......... remove the coil pack cover and leave it off or at least take a drill and drill some holes into it - lots! They tend to get extremely hot.... my old Silvia originally had a CA and when I went to remove the harness from the coils the harness connectors crumbled ! Wiring was brittle etc.... I had the same sort of nightmares regarding a miss and turned out to be broken wiring in the coil pack harness..... caused hours of frustration!
Cheers,
Anna
Cheers,
Anna
I don't actually have coil packs though, I have haltech ignition leads or something.. As seen in this picture..
Should be getting looked at this weekend sometime I think.. You're probably right about brittle wiring though.. I need to go over everything with a test lamp I think..
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
