Yeah the low/mid range on them is fking awesome, I could floor it in second in the wet and it'd hit full boost at 2500 revs and just crab down the road. All it had was soft as Tein Type NAs, Cusco sway bars, cooler, exhaust, brutal Cusco clutch and a massive alloy rad.
Some of the pro SA drift guys passengered with me for a few laps at the drift school and they couldn't believe how much torque it had. Around the back hairpin I'd be feathering it in 2nd with the speedo reading about 40-50ish (maybe 3000 rpm) then squeeze the throttle on the exit and the needle would swing out to 120 like it's nothing.
Aussie ended up swapping the 81 and cressy for it he liked it that much :)
  • Replies 58
I was hoping to see this thing with a new set of kicks :)
Please PleasePleasePleasePleasePleasePleasePleasePleasePleasePleasePleasePleasePleasePl
asePleasePleasePleasePleasePleasePleasePleasePleasePleasePleasePleasePleasePleas
Sell me your C piller trim :(
I'll put my interim wheel set up on it soon and it should look aight, and I'm gonna make it a bit of a mission to get it looking good enough to drive this week cause I'm fkn sick of the Lancer :P
But yeah gotta get back into a 100 hey.
Wooo she's back :D
Got the bumper sitting ok and bashed the left rear out as best I could and threw it all together and this is what I ended up with:
Ghetto fabulous :D
Needs a few little things as a result of sitting for so long, but overall it's pretty much back to a driveable state, although I'll be keeping a very low profile.
Ok interim wheel setup has fallen over slighty, teh centre bore on my Watanabes don't fit over the hubcentric bit on the spacers :D Good news is, they fit my other fronts, so I'm going to fit the stage 1 front set up and throw the BBS on the back for the time being :/
I have test fitted the SSRs on the front and all I can say is my predictions were spot on. 8j +20 with a 20mm spacer to make 8j +0, they hang out of the guards by a few cm, and clear the brakes perfectly - exactly what I ws after :D :D
I'll post pics later this arvo :)
Pictars as promised. The more I look at this the more I think I should keep it :)
And the obligatory fitment shots :)
Pretty stoked with how it's looking. When the 16 x 9s rock up I'll put them on the back and play with the height (and put the lip back on) and it should look pretty fking tough.
  • 4 weeks later...
Okay, it's been a long time coming (you get that with sea mail) but finally, the wheel set up is complete. For the technically minded, the specs are as follows:
Front
16 x 8j +20 (with a 20mm spacer effecting an offset of 0) running a 205/45 tyre with ~3.5 * camber
Rear
16 x 9j +13 running a 205/50 with ~3* camber.
Now on the interesting bit...
PICS :(
Yeah I took it off after I went for a short drive and had to try and avoid those little reflective thingys for fear of ripping it off :(
Got a short vid of it cruising along with the lip and all and fk me it looks sooo tough (also got a vid of me busting a quick handbrake U turn in the main street, and it looked fking cool doing that too :D)
I went an took a few more pics today, as tomorrow she goes in to get some shit done (cradle bushes and lock spacers) and I'm putting the stockies back on and raising it to a ridiculous height so I can cruise around without fear of getting done :ermm:
Edited by AndrewJZX100
  • 1 month later...
Well, it's back to looking stockish now. R33 stockies, a smidge below standard height, looks pretty lame :P
Good thing though is it slides better than it did before :) got alloy cradle bushes put in and steering lock spacers. The cradle bushes mean it now spins up instantly instead of jerking around and the extra lock means I can use the throttle to play with rear grip and keep it in check/bring it back instead of hitting the end of the rack and having to spin to stop.
Also MUCH better for busting quick Ueys from a stand still :wub: :wub:
Will hopefully get a tune and service in the near future as I might be getting a new job which will require me to do some kays in it.
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
    • Not a huge update because still waiting for some fittings for the intake. But I did corner weigh the car, its enough to make a GTR driver cry at 1163kg (race ready except no fuel)  Sorry about the terrible pics but I think they are readable With 70kg driver
    • The bumper you're talking about looks like this:  Rear wing is this different version which is more GTR-esque:
