It did look fair tough in real life, but white was always the plan so I painted it up and cleared it today, so now the wing and lip are ready to go, but I reckon I'll hold off on mounting them properly until I at least get some rims.
One more pic just before I took it off.
  • Replies 58
Maybe. 2 of the blokes at Adelaide Tyrepower had matching 4 doors, this was one. It did look fking tough with the Weds meshies it was sporting back in the day. Doesn't look so crash hot now though :(
Not gonna bother fixing it either, just gonna track it and thrash the crap out of it :) It has a fair bit of rust that was hidden before, so it's no great loss of a shell really.
Well I pulled the back out a little bit today with the aid of a tow rope + the cressida (ghetto style is how I roll). I can fit a tail light in there now and can almost fit the bumper back up so thats forward progress I spose.
And I also got bored so decided to chuck the lip on all painted. I reckon it looks aight (save for the fact it desperately needs wheels)
WOO WOO exhaust is fixed with a Blitz Nur Spec :D :D with the silencer in, it's fkn quiet as a mouse. No more waking the neighbours when I get home from work at like 3 - 4 in the morning :P:)
Reo is a wee bit closer to being aligned too, little more bashing to be done :cool:
tail lights sourced - minty fresh series 2 items for $65 each thank you very much :ban:
Also grabbed some alloy cradle lock spacers and steering lock spacers. Solid cradle and more lock shall be FTW when I get around to fitting them :O
Will take a heat gun to the bar later on and see if I can get it back to normal shape (or close enough to) :sick:
Getting there :P
Series 2 look ever so slightly different, in that they have reflectors in the middle of the hotplate bits and a horizontal crease line that lines up with the bottom of the boot/top of rear bar. I reckon they look a little nicer then the earlier tail lights.
I forgot to mention before, my SSRs rocked up too :O 16 x 8 +20. Fitted on the front with a 20mm spacer to clear the brakes should look pretty tough, but I'll do that when the 16 x 9 +16s I just bought arrive. Until then they are rears (will use aformentioned 20 mm spacer on the front with my 16 x 8 +38 Watanabes)
I've also come across some Fabulous (brand) rims available in 16inch with widths up to 10j and offsets that go right down to -31 :ban:
If the 9j I've just bought fit well on the front, I'll go 10j +12 on the rear :sick:
Just wondering, why did you sell your jzx100?
Because I am a f**king idiot :domokun:
No seriously, get one. Nothing will seem as good any more (hence why I have absolutely no problem throwing the 32 into a cliff, it's only skyline junk to me)
I'd get another one but I'm trying to slow down spending on cars (modding them is pretty exxy).
Edited by AndrewJZX100
haha ok then. I thought that maybe they didn't feel sporty or something as they look much bigger. Iv never been in one. Their just SO hot. Wanna send me some pics? I remember yours out at lala, even think i got some footage. Same day i was out on track. Looked like it had some go!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
