Had a bit of a search around and found some possible similar situations but still want some opinions
heres my problem:
My 1994 R33 GTS-t will drive pretty much perfectly fine, runs well, but when i put the clutch in (say at a stop sign/traffic lights) then it dies most of the time
before i had a play around with it adjusting the idle and checking the bov and everything seems ok (questioning wether or not i may have damaged the gasket when putting on an aftermarket bov for a week)
after i had it all bak together and had the idle sitting at about 800rpm i took it for a drive, ran beautifully, dropped to probably minimum of 700 rpm before going straight back up to where i set it, no problems
went out for tea, was fine on the way there and fine as i left
went to see one of my mates and as i pulled up at their place it started doing the stalling thing again
everytime i started the car back up itd jump up to probably 1200rpm then go back down and stall again
anyways drove it around a bit more, was still doing it so had to be constantly on the accelerator to keep it from stalling
got home and it stalled twice i think and i restarted it and it sat on about 1000rpm perfectly.......
now its a weird one, im thinking it has something to do with the AAC valve or maybe the tps but im not sure
i also think it has something to do with the bov cause i changed to a blitz bov for about a week with a home made adapter plate that was pretty much just a flat bit of steel with a pipe coming out of one side, only thing i really could have damaged here is the gasket though.
not sure anyway, need some help so everyone tell me what u think
very much appreciate any help and am happy to give more information if required
Cheers
https://www.sau.com.au/forums/topic/216682-car-dying-when-returning-to-idle/
more often than not, if something starts playing up after you've made changes then it's related.
So yeah, i'd say it's almost certainly related to your work around the bov.
You shouldn't have needed to play with the idle mixtures (unless you changed them when installing the blitz one) so i'd suggest that there was an issues there straight away and it's getting worse.
Check for a split hose on the feed as well.
just checked the bov, aac valve and afm
cleaned the aac valve with carby cleaner and sprayed a bit on the hot wire of the afm
still no success
doing it just as bad as b4
also cleaned the plugs with contact cleaner
bov has been tightened to 15ftlb on in 5ftlb incriments and checked it all out and it looked ok
its intermittent to a large degree, sometimes it will return to idle perfectly, other times it dies, other times it almost dies then picks back up
also has a unhappy idle at times where it will drop and raise 100 or 200 rpm constantly
atm looks like im just gunna take it in to get done under warranty, went in there today and they said to try cleaning the aac valve and afm hot wire and if that failed take it back to them
but still want to know what everyone thinks will be wrong with it, just to try and make it easier for them
also it seems to be worse at night time, will run good during the day and only stall every so often but as soon as it starts getting dark it gets worse
any additional information needed to help im more then happy to supply
cheers
EDIT: the only split in a hose is on the plumback hose that comes off the bov, but its a very small split that is half a centimetre if that, the hose clamp well and truly clamps the full circumference of the hose and i dont think that will be the problem
Edited by Boostin96
The problem is that you have fitted an externally venting BOV for that extra special sound that you love so much. Unfortunately, this is air that was previously recirculated into the intake manifold after the AFM. Your ECU is tuned to expect this air, but now it's gone.
End result? Your engine is running very very rich, and stalling.
How do you confirm this is the problem? Re-fit your stock BOV, or re-plumb your new one, and see if it fixes the problem. If it fixes the problem, the permanent fix is obvious:
1. Either plumb back your new BOV, or
2. Get a new ECU, and usually these can be tuned to stop the stalling
3. Increase your idle speed by opening up your AAC valve.
the stock bov has been back on the car for about 2 weeks or so now
went and played a bit more b4, ended up resetting the ecu (disconecting the battery and pressing foot on brake pedal for a bit)
plugged it back in and it seems to be alot better since but problem might come back tomorrow, it ran very well and held idle perfectly when i went for a drive and after i came bak, took the car out of the front and it almost stalled once but that may have been just been me
if it plays up tomorrow i think ill just take it into get fixed under warranty
or if anyone else has any theorys let me know
NOTE: I do have the stock bov back on, i mustnt have mentioned that in my previous posts, it actually ran fine with the aftermarket bov as far as i can remember to.....
Cheers
Cheers
If that is the case, then it's a simple leak somewhere :D
I have the same problem on my car.
I have noticed alot of the time it happens when steering is on hard lock. which makes me think power steering pump strains the engine.
But it also occurs when in a straight line slowing down to lights etc so who goddamn knows! :D
Ive also tried cleaning the AAC valve and AFM to no avail!
If anyone has solved this please post it up!
Thanks
-Dragonforce
hasnt missed a beat today, Dragonforce: try resetting ur ECU
quick search would tell u how to do that but its pretty easy, just unplug battery and put ur foot on the brake for a few seconds
no problems at all with the car stalling now, returns to idle perfectly and runs a little bit better i think
Ive had the same problem with my car it used too always stall after driving hard but then would happen even when just pulling into a petrol station. I blocked up the standard BOV and it doesn happen as much but still happens in a few weeks buying a Power Fc and getting tuned hope it then goes away......
Its a known problem with 33's
Its ONLY a problem with people who remove/fiddle with the stock BOV.
If you leave the stocker there (or replace with a GTR one) you will never have a problem.
Sounds like a split hose somewhere in this instance as the stock BOV has been replaced.
Not stock BOV equipped skyline will stall (if other things like the TPS, AAC etc are all working too)
I had the same problem and i didnt even touched the standard bov i blocked it up just incase there was a leak and still the same problem so must be something else....
I had the same problem with my old r33 which was stock as bar exhaust and the problem ended up being the idle speed control motor, put a new one in and was good as gold after that. Just my 2 cents of input.
Cheers Andrew.
Yeah, like the AAC, TPS and so on (general maint issues)
  • 1 month later...
like i said, reset ur ecu
thats how i fixed mine, lol forgot this was my thread but other ppl seem to still be stumped, reset ur ecu and it should be fine if uve run an aftermarket bov then gone back to normal only for it to stall
Edited by Boostin96
