some suggestions as to where i might have a leak (common places)?
:dry:
That pipe, from the return line on your BOV.
Put some duct tape over it (Alot) and I bet it goes away. Then, go buy a new return line.
i had this same issue.... but i had aftermarket turbo q45 afm etc. wat it was is when 20psi of boosted air was being pushed into the intake infront of the turbo it was forcing air back out of the intake aka backwards through the afm..... which basically mean night night when clutch is depressed after u left off the throttle and valves open up. now i run 2 stock valves (modified) and i would doubt ur 1 stock valve would have the capacity to cause this kind of a problem but check it neways mate cant hurt.
went back to stock for a bit but just put a greddy bov on
have found that it will work fine if the bov closes fully on idle, but for some reason its opening slightly, as if it has to much vacum
if i hold it closed and just give it a bit of revs and let it drop back to idle it idles fine
any ideas on how i can reduce the vacum? dont really want to make it any harder as its close to the point were it will frequently give me compressor surge
I'm not sure if this will help but I had something similar in my series 1 r33 gtst stock cept for a Turbosmart s2 BOV and K&N air filter.
It would stall when pulling up to lights.
My mechanic said it was the air filter getting blocked, not enough air getting through. I got my air filter cleaned and the problem has stopped.
Might be worth cleaning/replacing your air filter
ill give that a go
had a play with it last night, hooked my bov up to where my fuel regulator (i think thats wat it is anyway) is hooked up and just left the hole where u usually hook the bov up to on the plenum open so it had a vacum leak basically and it idled perfectly..... so my idea and i dont think its a very good one is to t-piece off the fuel reg or watever i used last night and make a line to go to the bov from there and then i dunno wat ill do with the other hole, as soon as i blocked it off though with my bov running to the front hole in the plenum it would stall so it would only work when it had a vacum leak....
ideas?
haha yeh, i think its just the fact that its leaking vacum so its not trying to pull the bov up therefore its not opening that little bit that makes it stall
going to do the sensible thing and see if i can make it recurculate by making a replacement for the trumpet, dont believe i will lose much sound this way (?) and it will be legal and should hopefully idle right
just so i know, can anyone verify that it will idle fine if the bov is open a bit on idle if its on recirculate? im thinking it will but will be nice to know before doing it to save troubles.
Thanks
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
