yes they will, however as far as im aware there's different shading/smoked effect on the projector for gtr? although i could be wroung
yeah pretty much wrong, no smoking effect
theres 3 different ones, standard GTR, standard GTS-T and the N1 GTR headlights
https://www.sau.com.au/forums/topic/216687-question/#findComment-3829840
There are two types of headlights. The ones which had the projectors and one with the reflectors.
The N1s had the reflectors, they're different to the standard reflectors cause they had the brackets for the grill (they're the same headlight).
The reflectors would be lighter than the projectors that's why they were used in the N1s.
Edit: Have a read of what funkymonkey's said.
http://www.skylinesaustralia.com/forums/in...t&p=3826106
Edited by adam-__-
https://www.sau.com.au/forums/topic/216687-question/#findComment-3830584
so they are different headlights
https://www.sau.com.au/forums/topic/216687-question/#findComment-3831667
You'll be able to use the bonnet either way. Do you have the brackets to mount the grill? If not, you could always just 'make' brackets for them. That's what people do to the 'povo pack' headlights and sell them as N1 items.
https://www.sau.com.au/forums/topic/216687-question/#findComment-3840197
the two brackets at the bottom are the ones you need to get if your headlights don't already have em. Contact Laurence on the forums to get a pair.
Failing that you can go ghetto and bend two pieces of aluminium and make a stay for the grille.
https://www.sau.com.au/forums/topic/216687-question/#findComment-3840952
