yes they will, however as far as im aware there's different shading/smoked effect on the projector for gtr? although i could be wroung
yeah pretty much wrong, no smoking effect
theres 3 different ones, standard GTR, standard GTS-T and the N1 GTR headlights
https://www.sau.com.au/forums/topic/216687-question/#findComment-3829840
There are two types of headlights. The ones which had the projectors and one with the reflectors.
The N1s had the reflectors, they're different to the standard reflectors cause they had the brackets for the grill (they're the same headlight).
The reflectors would be lighter than the projectors that's why they were used in the N1s.
Edit: Have a read of what funkymonkey's said.
http://www.skylinesaustralia.com/forums/in...t&p=3826106
Edited by adam-__-
https://www.sau.com.au/forums/topic/216687-question/#findComment-3830584
so they are different headlights
https://www.sau.com.au/forums/topic/216687-question/#findComment-3831667
You'll be able to use the bonnet either way. Do you have the brackets to mount the grill? If not, you could always just 'make' brackets for them. That's what people do to the 'povo pack' headlights and sell them as N1 items.
https://www.sau.com.au/forums/topic/216687-question/#findComment-3840197
the two brackets at the bottom are the ones you need to get if your headlights don't already have em. Contact Laurence on the forums to get a pair.
Failing that you can go ghetto and bend two pieces of aluminium and make a stay for the grille.
https://www.sau.com.au/forums/topic/216687-question/#findComment-3840952
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
