Hi,
Just thought I'd do as it asks and introduce myself. I live on the Gold Coast and have done for the last 11 years. Got my first import in 1998
, S13 K series and ended up putting an RB20DET into it a few years later. Did join here many years ago but lost my login.
Peace,
James
https://www.sau.com.au/forums/topic/216713-hi/
It's a bit sad, Just sold my 1990 r31 and the Silvia was sold like 4 + years ago ;) Now I drive a 1997 Toyota Hiace Super Custom turbo diesel:) Will get back into an r34 or S15 soon though I hope. Gotta love all the dickheads that wrecked it for everyone (new laws etc,.). Sometimes I wonder how so many Australians found out about cool imports, maybe many found out through Play Station's GT1 and 2 and crap like fast and the furious.
Edited by Doof Van
https://www.sau.com.au/forums/topic/216713-hi/#findComment-3834831
    • No concern, especially not on E85 you won't really have an issue with moisture. You could put a ball valve on it and only open it when you're going to punish the car. On daily commutes you wouldn't need it open to vent the crank case. I would say it's above the oil, considering that looks like it would sit above the windage tray
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
