My Epic R32 Rebuild
So I figured I'd make some sort of photo diary of the work being done to my car at Driftline down in Campbellfield, VIC.
Having hit a runaway gate at DECA (thanks for securing the gate with a watering hose... real intelligent) a year n a bit ago, the car's been looking a little sorry and often referred to as the ghetto R32. but no more... with a fresh lick of satin black, full kit, flared fenders and some other bits, it should come out looking mint.
So first the raw materials:
Take 1 beaten up R32
Add:
1 bonnet
2 pumped D-Max front fenders from Empire Aero
2 pumped rear fender flares from Viva Garage
1 Type J Front Bumper from Viva Garage
2 vertex sideskirts and rear bumper from Viva Garage
1 open grille, 2 GTR grill clips, and 1 V-Spec bonnet lip from Laurence (gojira/dr1ft.jp)
a set of Work VS-XX in 17" by custom offsets to fill out the fenders for flush fitment
Wheels have been taken apart atm to have custom outer bands machined and have the centres powdercoated black to match the car.
Update (from a while back):
  • Replies 41
the guys at the workshop decided to fit up the Viva Garage supplied rear quarters today.
I got an abusive phone call from Roshan, for supplying shit quality quarters that didn't line up with the door line or boot line. His options were "throw them away... or cut them up and make them fit"... the latter will cost a lot more time, which we don't have, so the hunt is on for better quality flared rear quarter fenders.
He said he took some pics of it on the car to show how horribly out they were. Should be interesting.
for sure, should've gotten the rears from Empire Aero as well along with the fronts... but we had already ordered the rears from Viva, so that's why we're in this predicament. Contacted Empire about getting rears as well... lets see how we go.
well just to update, today we decided to chop the Viva gaurds (remove the lips that are supposed to go under the boot and door etc) and redo the glass.
Haven't decided on how to blend it... a full blend will require the windows out etc... which is a long and complex process. probably won't go with the option... this means we'll have to go with a more ghetto look for the rears, with the panel edges visible ;)
thats not very Epic Shan..
go the whole hog .. no point spending the cash for a ful spray and leave that little bit bugging you forever.
if we were to take the glass out etc it'd extend the timeframe by two weeks... its the main deciding factor...
we're gonna try and do some tricky stuff to blend it in... without blending it in. it'll either turn out shit... or epic ;)
the respray is only the outer panels and edges n door jams etc... engine bay's already black as is the inside of the boot etc...
the other alternative is to flare the metal out... but cos of the track damage on the driver side it's pretty hard... easier to just cover the battle scars with fibreglass.
  • 4 weeks later...
lol the P plates was a shock to me too... then I realised I had to get my cuz to drive my car to the shop cos I was in brissy, so he had to put em up. hope he didn't munt the clutch like last time by riding it.
i recently brought a full r32 viva garage kit from a friend for $200. i will be throwing the sideskirts away as they are so bull shit its not funny. rear bar was the best fitting after i cut and shut it heaps and the front bar needed a fir bit of time aswell. well the front bar was almost straight. had to fold the sides in heaps. pretty crap realy. worse for the bloke i brought it off as it cost him $1200 and sat in his shed for 12 months.
sorry to hijack just thought i would emphasise that fact
 Share
    • Nice write up solder thank you.  that problem had fallen into another days fun. I wanted to get this cold side in and turned over so it was wired up the same to get a start. no luck I got a couple of cough’s before the battery died unfortunately. we have some wether on the way and I’m back to work, I will order your plugs and re wire them in the near future. 🤙
    • It was simpler than that. Few things going on. One is that I hate plastic clutch alignment tools. Anybody who reads this in the future and is considering one, don't. Even for 3 USD it's not worth it. Mine left plastic shreds all over the inside of the clutch hub. Now I need a proper steel one and to re-grease the hub splines very carefully without leaving any excess that could go into the friction disk or anywhere else unintended. The second is that I'm bad at reading directions. There is a step in the instruction manual that tells you to put in the 3 M6 bolts BEFORE you attempt to put the clutch onto the flywheel which has been bolted to the crank. You should tighten them slowly and evenly in half turn increments so the springs all compress evenly. Once hand tight back it off until the friction disk can move around between the midplate and the pressure plate. Otherwise the hub won't be able to move properly to line up everything. The last point which is possibly the most important and is not mentioned in the manual or anywhere at all is that the friction disks are actually not symmetrical. There is a very, very subtle asymmetry to the fingers where they mesh with the hub. These fingers need to be pointing towards the midplate. This helps to make sure the friction disks stay engaged with the hub. Otherwise there is a distinct risk they pop up and out of the hub while you assemble, leading to the warped pressure plate I posted initially.
    • ..m'kay.... I see on my phone you're having difficulties interpreting the artfully hand drawn R31 wiring diagrams... you wouldn't credit it, but they're actually more accurate than those colour diagrams in gregory's and the like... ...for your purposes though, the wiring colour legend is on sheet 1.... ....the fuel pump connector is top right on sheet 2.... ...pin1 (black) goes to chassis ground -- pin5 (light green/red trace)... The best way to navigate those drawings, is to open them up in whatever image manipulation/paint program you like, and use the straight line/ruler  tool (with a highlight colour) to trace along the wire lines...not hard, no rocket science involved... Fun facts: The OEM diagrams are drawn to top trim level spec ~ so for example, you're looking at Silo spec wiring, but the base S3 Executive trim is also covered by the same drawing (base models just don't have all the add-on luxury bits) One of the more sublime bits of errata, is this bit... The wire splice between pins7,14 doesn't exist (red) -- the bridge on the cluster PCB between the same pins (green) does exist...but it's not 'there' physically...it's actually more towards the center of the PCB, exactly at the spot where they tend to crack...and if it does, only half the dash lights work... can drive you nuts chasing it ; don't ; just solder in the missing splice... These are 'intentional' soldered and taped splices inside the loom(s) ~ there's also unintentional splices like this, due to manufacturing process when a spool of one particular coloured wire runs out, and they splice in/on a new spool. Those splices above are in the loom, LHS, underneath the front guard panel (remove to get at loom)... if water's gotten into the looms, you can expect corrosion at these splices ... keep this stuff in mind, if in the future you get any weird electrical faults... 👍
    • that looks identical to the WGNC34 Stagea one I was poking around the other day. Is the other end of that not the ECU plug? If so checking continuity at both ends will tell you which ECU wire it is.  I can start by telling you ECU pin 31 is the top of the large pins on the right in your second pic
