More pics.... clearly the Type J front bumper and the vertex aren't are good match... and considering the vertex bumper we received was about 2 inches out of meeting up with the panels when mounted... might be a blessing in disguise.
  • Replies 41
Posted Images
you guys can make up your own minds about the quality of the guards n bumpers :blush:
needless to say there's gonna be a bit of work left before it all starts looking good... and unfortunately a bit of fibreglass and bog to go with it.
There's alot of space under the guards now..
What offset/width Work VS-XX's?
Theres nothing worse than wrong offsets :thumbsup:
wheel offsets are 9.5" width with -10 offset up front and 10" width with -16 offset at the back. although that's tentative... I haven't ordered the outer bands for the wheels from japan yet... will be ordering them to suit the width of the car so it just sits a couple of mm outside of flush. Being a 3 piece its really handy cos you can alter the width to taste.
WOW - thats ummm ..... nasty?
atleast the extra work will ensure it looks great, but will cost you a bunch to do.
if you can, get lots of pics of the prep work to make them work, always interested in new techniques for fixing this sort of stuff.
indeed... luckily I actually work for the shop (well used to while I was in melb) and I've seen worse kits come in on cars, and go out looking really good, so I trust that the work will get done properly.
Chris, I actually wanted to talk to you about gettin some stuff powdercoated, specifically the brakes, engine covers and wheel centres. PM?
Oooooh details on the bonnet?!?!?!
sorry the one pictured in the first post isn't the one I ended up getting. Updated now.
Got a D-Max copy bonnet in the end from Viva Garage. Driver side of the bonnet sits 1cm above the guard compared to the passenger side which sits flush. will have to cut away at it in places to make it sit flush on both sides.
here's the original in CF:
Thats pretty good looking!
Got a pic of the underside of it?
Price?
I cant shut my bonnet after the rb30 and highmount turbo - so im after a bonnet with heaps of clearance near the timing belt cover
wow i cant believe you keep buying this stuff off viva as the fitment of the pieces isnt getting any better.
i had one of the type J front bars. took a bit of work to make it fit. had to pull the sides in about 100mm each side and cut a bit out of the back of the sides to i could turn my wheels. once it was painted up it looked really good. at-least for 12 hours until i smashed it up big time on a ripple strip. i would defiantly buy another one as you dont see them very often.
should look really good. keep it up.
funnily enough the Type J front bumper is the only item that fitted up perfectly with no mods :)
ah well... got BN Sport sides n rear now :cheers: car looks hektik drifter styles... but at least it suits the type J front.
Whats the number to ring re your front bar? Also, woudl they have astd rear bar layign around with goos side clips?
my standard rear bar should be at the shop still. the number is 0425855540, the guys name is Roshan, he owns driftline.
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
