with increasing numbers of V35 skylines and M35 stageas coming in, and nissan platforms now going to VQ engines and differeint interiors to the older R-series skylines, it seems SAU has grown and will continue to grow with many users having newer models each day
it was great to firstly see the V-series skylines getting our own section.
The V35 (coupe and sedan) is for sale everywhere now and the V36 is soon to follow.
Similar cars such as the Z33 350z, M35 stagea, fuga, and cima are also coming in more and more and ar e all based on the same platform
now what i propose has been discussed quite a bit already in the V-series section, and has even been suggested by funkymonkey as being a good idea that he has goign to impliment:
http://www.skylinesaustralia.com/forums/in...t&p=3722046
the problem we have with our cars is that parts are more difficult to come by than for the R-series skylines. parts that are easily interchangible between R31/32/33/34 cars just don't fit the V35 / M35 / Z33 / Y50 or are more of a downgrade.
given the high turnover of threads in the normal for sale section, its almost impossible to find a thread for our cars even if it were available as we never look in there because its simply impossible to find parts
what i propose is that we have a dedicated for sale section for "newer model nissans" or simply for "V-series skylines" if you would prefer to keep the skyline name going. it would benefit all owners in the above groups and given that more and more people are buying newer nissans, this will ultimately benefit SAU as a whole and compliment the ever-growing V-series section perfectly
it could be set-up as per the current stagea for sale section, where is appears at the top of the regular for sale section but is linked to also appear at the top of the V-series section
I would be very keen to see what prank has to say about this idea, and what other mods feel about it
cheers,
Warren
https://www.sau.com.au/forums/topic/216770-new-model-for-sale-section/
Easy Warren, its a fair bit to stomach and think about.
I read it yesterday but im gonna let my brain think for a few days as probably everyone else is no doubt.
Suggestions, give them a good week... no real rush is there?
thanks duncan...
if you don't go ahead with it, and i can see some reasons you would consider to not go with it, can you give some feedback so that we can know why
i personally think its a great opportunity to help SAU grow
just think in 10 years time how many V35/V36/R35's will be on the road and coule benefit from this
cheers,
Warren
Not really - Thread discussing this have turned into looking at doing a total redesign the For Sale area in one big sweep after the new forum version which has been tested and will be released shortly according to the big C.
Changes will encompass some things you have mentioned above, but with many new added features/requirements for threads and so on at this stage.
I'd say it will stay "as is" for now until the new solution is designed/built/tested as its looking pretty interesting so far :blink:
For the interim weeks - no worries, just remember your restricting your view if people use the search though as most people will select the FS section when searching.
If it gets out of control though (5+ a week) we'll have to peg it back as the section will just fill with FS threads and nothing useful to yourselves
  • 5 years later...
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
