so i have seriously searched for months and i cant find jack squat about these cars, i have one and the motor is pulled into a mazillion pieces, so i CBF putting it bck together and i can get a Y31 cima motor (vg30det) for 3k with all bolt ons, ooorr i can get a z32 (vg30dett) manual front cut for 2900...
so. i allready have the AUTO built so im staying auto but what i wanna know is are they any way different from the 300zx motor? apart from the obvious intake maniifold and exhaust manifold, and one is single and one is twin turbo.
but basicly i need to know can i just wack my single turbo manifolds and intake on the TT model and the cima ecu will run it? and have the same size injectors blah blah? or would it just be easier to buy the cima motor and go yay done.. mind you im going to be running a GT3082r and a 38mm external gate so yes it will need to be single turbo i hope you guys can help.
and maybe direct me to some info on the net?
Ryan.
https://www.sau.com.au/forums/topic/216798-y31-cima/
I would probably just stick to the VG30DET motor if I were you mate if you are going to stick with an auto setup....will likely avoid the potential trouble of using a Cima ECU on a 300ZX engine.
I have grand plans to stick a VG30DETT into my Cima when the orignal engine finally shits itself to convert it to a manual(hopefully for some drifto)
spend the extra $100 and save yourself alot of headaches I reacon mate
https://www.sau.com.au/forums/topic/216798-y31-cima/#findComment-3828183
yeah, its not so much just the extra 100 bucks, as the cima motor is just that, where as the z32 is a full front cut.sorry to be rude but how is the vg30dett any sort of upgrade to the vg30det? but yeah manual would be good if i hadnt already built the auto.. if you dont mind could you take some detailed photos of your engine bay mainly of sensors, loom and the associated plugs, as i bought the cima with no engine in it so i have no idea what goes where, im sure it wont be too hard but some pics would be nice for comparisons.
thanks heaps for the help bud, i think i will end up going for the cima motor, also do you have any pics or translations for the fuse diagrams and such?
Ryan.
https://www.sau.com.au/forums/topic/216798-y31-cima/#findComment-3828579
Only just bought it but I will sort some pics out for ya.
My mate had the fuse box translated to english so I will get that off him to.
Only advantage of vg30dett is access to a manual G/Box and TT setup.
VG30dett has bigger injectors
aint exactly a huge upgrade on the vg30det though
https://www.sau.com.au/forums/topic/216798-y31-cima/#findComment-3828670
The BIGGEST (and main) advantage to the DETT is the fact that it comes with better electronics from the getgo, like a maf that meters 480hp (instead of 300) or 370cc injectors (instead of 259cc) or intercoolers (instead of none), or an awesome fuel pump (instead of one that can barely do 300whp).
Both of the engines have stout bottom ends with pistons that fail about the same point (before 500ish whp).
(COPIED OFF ANOTHER SITE WHILE DOING RESEARCH)
https://www.sau.com.au/forums/topic/216798-y31-cima/#findComment-3829828
  • 2 months later...
here are a few pics of mine, i bought a complete running 88 cima so i dont have to build my shell, any way doing cooler in the next few weeks, trying for a kit and some 19-20s, and a nistune ecu ill keep updating this thread with pics to try help others
https://www.sau.com.au/forums/topic/216798-y31-cima/#findComment-4037183
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
