I have just built a 25/30 as my old 25 died at just under 400rwkw. I have Haltech E11v2 and am using Splitfire coils. I want to upgrade the ignition and was thinking about a MSD dis4 and mercury marine coils. Will this work with the haltech while running wasted spark?
What would be my best option to work with my ecu?
https://www.sau.com.au/forums/topic/216809-haltech-e11-what-ignition/
Why are you running wasted spark? You are decreasing the coil recharge time by 50%.
Run 6 ignition circuits with the Splitfires and it will be fine.
Cheers
Gary
so this would be better??
http://store.summitracing.com/egnsearch.as...mp;autoview=sku
MSD Digital-6 Plus CD Ignitions
Power, accuracy, and efficiency.
MSD has combined race-winning experience with leading-edge technology to offer these incredible Digital-6 Plus ignitions. The 15 MHz micro-controller can analyze up to 15,000,000 critical instructions per second! That's over three times faster than comparable ignitions. Every spark is packed with 135 millijoules of spark energy and 535 V of power. Built-in features on the MSD Digital-6 Plus ignition include two rotary switch adjustable rev limiters, a single-stage timing retard, a start-up timing retard, an LED fault display, EMI protection, and much more! You get complete combustion for greater power, quicker throttle response, smoother idling, and quicker starts. You always get more power with less current draw.
Surprisingly a dis-6 isnt a 6 channel cdi, its only one channel. To run 6 channel cdi, use a m&w pro-12, or a dis-4 and dis-2. I wouldnt have thought that the coil recharge time would be an issue when running wasted spark cdi, as there really isnt a recharge time. Also he is running an rb25/30 so there arent going to bo massive revs. PS 1jz's run waste spark from the factory and they dont seem to have ignition dramas. So do 4g63's
just get a HKS ignitor box, plenty of jap workshops running the factory coil (or replacement) with the HKS box, works a treat but hasnt really caught on here which i find odd considering its great and uses all the factory gear
i have a set of the haltech high power coilpacks for sale brand new in boxes for $480 (cost $650 new), my tuner reccomended them for over 35psi boost and 700rwhp+, the tuner runs these on his 2jz drag car running high 8's down the track and making 700hp so they are the ones to go for.
give me a PM if your keen
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
