R33 Parts Need To Go, Negotiable
Sold my car a few weeks ago so its time to get rid of some parts lying around.
all parts located in Birkdale/Capalaba (southside Brisbane)
pick up preferred but may post/deliver
all prices are negotiable
anyway here they are
Standard Parts
-R33 turbo rims - $150 - with tyres, will check how much tread left tommorrow
-R33 non-turbo rims - $50 - with tyres, Will check tread, one tyre have puncture which can be fixed
-R33 Manual Shifter - $20
Aftermarket Parts
-ARC Fmic Kit with Turnflow Core - $900 - Brand New Still in box and wrapping, never installed, uses standard piping route, paid $1250 from Japan
-Volk Racing F-Zero Challenge rims - $600 - 17x8 & 17x9.5 +??, tyres are pretty stuffed from what i cam tell but may still be useable, tread looks ok,
sidewall on one or two are a bit iffi, fits r33 perfect, gutter rash pretty bad on both left side rims, installed only once to see how the look/fit but never drove
on them because i wanted to get the gutter rash fixed first, looks like guy i bought them from couldn't park very well.
***more parts to come***
will get pics asap, also will add more parts tommorrow
contact me via PM or Mobile - 0401745977 or email - [email protected]
cheers Eli
already remembered more parts
-Standard R33 Gtst Turbo Back Exhaust with cat $100
-Standard R33 Dump Pipe - $20
-Custom 3" Catback exhaust - $300 - basically a straight design, split near the end into two 4" pipes, very loud, mild steel,
if matched to a highflow dump and cat it would make a great track exhaust. or you could leave the cat out all together :D
pics tommorrow
Ahh hah! Gear shift knob! Sold! :D
I've been needing one ever since I got my car and the stupid SAAS one is always coming loose, and gets too hot in sun. The replacement one (34 or something) I got doesn't fit right (thread doesn't actually reach).
Hopefully I get a call about my car being fixed soon, otherwise I'll borrow something to pick it up.
Edited by Hell Fire
ok, more standard parts
-S2 rear wing with light - $100 - silver paint is rough, not sure if light works, never tested it
-R33 Cat - $20
-S1 Steering Wheel - $20 - bit rough but still round :down:
-2x Left side skirts, 2x right side skirts - $50 for all 4 - one in great condition, others need platic weld, see pictures
-S1 Rear bar - $50 - White, pretty good condition, no need to paint if your cars white
-Plastics thingamabobs that sit inside front wheel well - FREE!!!!! what a bargain:)
also checked size of volks which are 17x8+32 & 17x9+40
Pics
more pics available of condition and everything so if you want some send me a pm with your email and ill send you them
still negotiable on parts:)
cheers, eli
Edited by ELI
Aaaaa, I'll take the front inner wheel guards too :rofl: Maybe the side skirts too, completing a car is a bitch :D.
PM me with times you're available for pickup and I'll borrow the discovery :(
What's the difference structurally between the turbo and non-turbo wheels? Different inside clearance for brakes?
 Share
    • The 5 spd AWD boxes are all like-for like. They might not all be identical (covering >10 yrs of production means that many parts were updated as they went) but they are the same thing. You're not going to be swapping to auto.
    • Oh, oops, yeah, I'm getting the cams in the 2.5 replaced, so the above factory 2.0 cam specs don't mean 5hit, but, after alot of googling it seems the factory 2.5 cams don't like to rev So, yeah, there is that 🤣
    • Update - new drop of oil noticed. Leak seems to be continuing, but a slow/small one.
    • Hey y'all! So I am the owner of a shiny new '99 ENR34 25GT-Four, 5spd manual. Took it to the tire shop to get new shoes. They mismatched the front and rear axles (225/40s on rear, 225/45s on front), so AWD system went bonkers for the next day. Took it back in, they fixed it, but I noticed about 8-9 big drops of red fluid in my parking spot. Leaking has stopped, but it's clear that the transfer case may have been stressed/hurt by this debacle. I'm taking it in for inspection tomorrow. If things are FUBAR, I have a few questions. - ENR34 manual transmission transfer cases seem impossible to source. Can a GTR transfer case fit? Or if not the whole thing, just seals or components? GTR is 6spd, mine's 5spd, so I'm thinking no, but lmk. - Finding a few RB25DE NEO AWD auto transmissions for sale, for decently cheap. If my only option is to swap to auto, what else will I need besides an auto-specific gauge cluster, and associated wiring? - I imagine the R32/33 GTS4 transmissions/transfer cases are a no-go? They're not NEO engines, so unsure. - RB25DET/4WD setup from the Stagea, any parts that transfer over? I did search up for this on SAU and google, very little info covered.   This is my first post, so apologies for breaking any rules, please let me know, and thanks for the help.
    • Thanks. I agree, looking at those plugs in conjunction with good compression/leak down tests I'm not too certain its ring related anymore.  I have a Swagelok ball valve on the drain and tubed it lower down to the left side of car to easily dump it into a container. I do not drain back into the sump. I've never had to drain it though as there's never been any oil in it.
