  • Replies 196
Posted Images
shit i so hope i can get there.
i just had to fork out excess dollars for my new clutch
X-treme single plate motorsport button clutch w/ chrome moly 10kg flywheel woohoo (designed for drift)
and my power steer pump is gone tooo.
god dam cars :D:)
let me know how it all goes for ya mate.....i am going to take my car there for kit fiting and painting so more reviews aye.....yay another northsider
Will do. I'm a bit worried about it, as I've seen the results of two front end repairs on my parents cars, and the finish on both were of a very poor quality. One was on a VB commodore, and the new bumper bar they installed started rusting through the chrome in under a year "oh, they were all like that mate..." "BS, look at the old one, that's over 20 years old and the only thing wrong with it is that it had an encounter with a towbar" and on the Cressida the new paint started flaking off within a year or two. And as they're repairing my bumper (it did its job well and sprung back into place) and respraying it, I'm a bit concerned, so hopefully they're as good as everyone here says!
I just found out that tonight I'm at dinner at 9! Right when the LAN starts. Next time Gadget!
^^^ zomg what a noob :D just kidding.
CS = version 1.6
CS:Source = latest Steam version
It's hard to describe the differences, but they are quite different games, even though they are the same game.
thats not PNP.rec is it?
Yeah mate, that is Jamie. Absolutely crazy player - the boy has skills. Has played for and won with the best clans in Australia at nationwide gaming contests.
lol thanks for clearing that up andrew! :D ... im just throwing out a false sence of security so everyone thinks im a noob at teh shoot em ups :D
i take it your coming tonight??
yeh damo im with ya on that one mate i hate it when my vag is sore...... bahahahaha. ur missin out see ya sat bud!
CS = version 1.6
last time i played cs would have been 5-6 years ago back on HL 1 :D
should get back into it
my plans have changed now so ill be able to come along see you guys in there.
look forward to getting whiped on a variety of games ive never seen before and going home playing my xbox and thinking its time to update this old crappy machine.
I'm out at the last minute.. No one to look after the young lad as the father in law has had to head interstate on business. :)
Im stuck in my office doing disaster recovery preps ;( If I can get there I will but apologies if I don't make it....
-D
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
